DC-AC 12V -110V/220V 500W or More Inverter
213,318
125
25
Introduction: DC-AC 12V -110V/220V 500W or More Inverter
i have constructed this inverter to charge my EV
i have 12V DC from solar pannels and i need to recharge my 120V battery pack so i needed an voltage inverter
after buying one i have tested it and it blowed in 2 hours
so i started building one myself using the ferite transformer and rewired it for my use
is very sinple and can be made for every one needs
can output any AC voltage with proper wiring
i use it only with 110v for my needs but in the diagram i had added another wiring for 110 and 120V
as you can see it powers an 200W halogen lamp for testing
in test i have used only 2 FETS but they are too hot so i have added another 2 for more power
if you use only 250W you can use only 2 with propper cooling
if you want more that 500W you need to add another 2 for every 250W of power and use an bigger transformer
from my findings this inverter has around 75% performance
Be carefull at output you have dangerous voltage
Step 1: The Built Inverter for 250W
as i said this one gets hotter with an 200W halogen lamp
if you want more power use more FETs and better transformer
DO NOT TRY MORE THAN 1000W is insane
for 250W you use 310W/12V=around 25A
for 500W you use 620W/12V=around 50A
for 750W you use 930W/12V=around 75A
for 1000W you use 1240W/12V=around 100A
Step 2:
you can use an inverter to power your laptop from car batetry or use any house object that uses AC curent
this is the test inverter finished
i will post more pictures after i finish mounting it in its casing for car mounting
i have 240W solar panel on the roof of my car so i can charge my car anywere is i have enough time
for DC you need to add an AC/DC rectifier and you can charge your EV battery ;)
BE CATREFULL YOU ARE PLAING WITH DANGEROUS VOLTAGE
Homemade Holidays Contest
Be the First to Share
    • Robots Contest
      Robots Contest
    • Sewing Challenge
      Sewing Challenge
    • 3D Printed Student Design Challenge
    25 Comments
    chiboy828
    chiboy828
    4 years ago
    please I need a working 3000watt inverter lesser circuit. I have built one but I need a different circuit of 3kva. here is my email. chiboy828@gmail.com tnx
    harim70
    harim70
    5 years ago
    hi,
    thanks for your information and could you clarify these questions to me?
    1. what are the part number of T1 ( transformer) and FET ?
    2. If I want to change this circuit to 500W How are the parts can change? obviously the flops or LM555 will change because obviously these parts cannot handle 50A current
    3. what is the efficiency of this system?
    could you reply to hmahaling@gmail.com
    thanks
    hari
    LelandC
    LelandC
    5 years ago
    Not a well suited inverter since it looks like a pulse driven square wave.
    devshekh21
    devshekh21
    5 years ago
    sir, what is clk component...
    LelandC
    LelandC
    Reply 5 years ago
    Looks like a 555 timer going into a 4013 D-type Flip-Flop.
    AnandaJ1
    AnandaJ1
    5 years ago
    please give me a 3000w transformer less inverter circuir diagram
    anandahyatt@gmail.com
    erdin.halil
    erdin.halil
    7 years ago on Introduction
    Hi, I know its been a along time since you made this but can you tell me, what will happen to the power output if part of the solar panel is in the shade. Can a voltage regulator be implemented to address any problems caused by shade?
    Thinking about using something like this to push a dryer motor in a go cart.
    useless018
    useless018
    9 years ago on Introduction
    hello jerpelea,, can u help me with my project my professor instruct us to built an inverter that has a 5Ampere output current,,,, can you send me all that is needed in order to build it,, (schematic diagram, pcb layout, devices use etc.) thanks for your help... and thank you in GOD speed ^_^
    this is my email add: please.helpme018@gmail.com
    HARRIS747
    HARRIS747
    Hello Folks,
    I cannot read the component names from this img.
    Any of you who has build this inverter can please tell the forum the components used and the transformer windingdata ?
    Thanks very much, and best regards.
    johnybody
    johnybody
    10 years ago on Introduction
    Is the Flip-FLop gate is a 4013?, like this one: CD4013BE
    Thanks
    alex young
    alex young
    Hello what changes can I make to use this circuit work with 24vv Is this output pure sine wave. Looking for a reply . Thank u
    mahdiazizi110
    mahdiazizi110
    hi
    thanks for the circuit
    i m a fan of electronics as a hobby, i just do it for pleasure so i don't have much information about it,at all is the circuit easy for an amateur?
    i want an output of 220 volts,what should i do?
    and what current it needs in the input?can i use an motor bike battery for the input?
    the last is can it turn on TV?
    again thanks!
