DC Motor Controller for Electric Bicycle
Intro: DC Motor Controller for Electric Bicycle
I designed this controller for my Crystalite Sparrow 48V electric bicycle hub motor. The core function of a DC motor controller is to periodically read the throttle setting and adjust the current being supplied to the motor. It does this with a technique called pulse-width modulation or PWM (more on this later). Other functions of the controller include: 1) low-voltage cutoff .. monitor the battery voltage and shut down the motor if the battery voltage is too low .. this protects the battery from over-discharge. 2) over-temperature cutoff .. monitor the temperature of the FET power transistors and shut down the motor if they become too hot .. this protects the FET power transistors. 3) over-current cutoff .. reduce the current to the motor if too much current is being supplied .. this protects both the motor and the the FET power transistors. 4) brake cutoff .. shut down the motor when the brake is applied .. this is a safety feature .. if the user applies brake and throttle, the brakes win.
Note1: This is a relatively advanced instructable. Don't attempt it if you don't have experience with power electronics. The voltages and currents used in this project can be dangerous and appropriate safety precautions must be used. This instructable outlines what I did to make this project, but it is not a substitute for proper safety training in power electronics. Check with your local community college for availability of classes in your area.
Note2: In addition to the 48V battery voltage, this controller requires a 12V power supply. If your battery pack consists of 12V cells, then you can just tap 12V from the pack. This was not possible for my battery pack, so I used a separate DC-to-DC converter to supply the 12V power. See my other instructable on constructing this DC-to-DC converter.
Note3: This controller is over-designed for this application. The IRFP4468 FETs are rated for a maximum of 195 Amps (each) at 100V. This application will typically use less than 10 Amps at 50V. I have been commuting (10 mile round trip) almost every day for the past 2 months using this controller and it has been trouble free (knock-on-wood :)
STEP 1: Parts List
Here is the parts list (with Digikey part numbers) for all the electronic parts.
You will also need:
a) a prototype circuit board (the one I used is from a local electronics surplus store)
b) wire. I used 30AWG wire for the low current connections and 14, 12 and 10AWG wire for higher current connections.
c) 1/8" heat shrink tubing (about 2" in length)
d) two 6-32 x 1" screws
e) 4 x insulating pads for the FETs and power diodes (these can be salvaged from a broken PC power supply)
f) a heat sink for the power section. (this can be salvaged from a broken PC power supply)
g) an enclosure. (this can be salvaged from a broken PC power supply)
The following tools are required:
a) a programmer for the microcontroller. I used an AVR ISP programmer (check EBay)
b) a soldering iron (and solder of course)
The following tools are recommended for debugging:
a) a digital multimetter (DMM) for checking connections, etc.
b) an oscilloscope is handy for checking the PWM waveform, etc.
You will also need:
STEP 2: Schematic Drawings
Here are the schematic drawings. Sheet 1 is the digital section and sheet 2 is the power section.
STEP 3: Digital Section
This photo shows the digital section (page 1 of the schematic) wired up and connected the the Atmel programmer.
STEP 4: Pulse-Width Modulation (PWM)
This photo shows the PWM signal (pin 15 of the ATMega8 micro) used to turn on/off the power FETs. When the signal is high, voltage is applied to the motor. This waveform is for about a 1/4 throttle setting.
STEP 5: Power Section Construction Details
These photos show how the FETs and power diodes are attached to the heat sink. They must be kept electrically isolated from the heat sink. The screws are covered with 1/8" heat shrink tubing and the FET and power The heat sink that I used is re-purposed from an old broken PC power supply.
STEP 6: Assembly and Enclosure
These photos show the controller with digital PWM and power sections completed. The monitors (e.g. battery voltage monitor) are not connected yet.
STEP 7: Circuit Board Layout
I used a circuit board CAD program to create this layout. I have not fabricated this circuit board.
STEP 8: Software
The software is not currently available ..
73 Comments
vinayakd7 2 years ago
Boyginius 5 years ago
kruthik 5 years ago
scd 5 years ago
engineerscubicle 5 years ago
https://circuit-diagramz.com/circuit-diagram-of-electric-bike-controller-for-motor/
HandsomeJoe 6 years ago
quartetman1 6 years ago
Hello,
Background information. For an aquarium. DC controller to run a 24 volt DC motor to run water pump. This motor is a DC 9-24 volt, powered off a 24 volt marine battery, if a power outage takes place, the pump would still run. And yes, I will have a battery charger charging the battery 24 X 7 X 365.
What's needed. A controller that will be variable and not go below 9 volts and not above 24 volts. If the water flow is to high at 24 volts, the controller would be turned to reduce the motor speed, there by reducing pump flow. This pump would be running 24 X 7 X 365, with exception for powering down to change cartridge filter.
This controller would not be powered from the 120 volt 60 hertz house power. This controller is powered by the DC 24 volt battery.
Plese include safety circuits also. Overheat protection, over voltage protection, etc.
Note this will not be a throttle type of speed control. The speed would be variable to the point of a stationary set speed according to water flow, and then continuous run at that speed. ??Would this be a potientiometer which is similar to a volume control for audio equipement??
Could you design a circuit to function like this?
Thanks, Ken
scd 6 years ago
Nuzhatn 6 years ago
mahio4u 6 years ago
Nice instructable. I have some questions.
1. What was your switching frequency, and why did you choose that value?
2. What was your PWM boundary? as in 0 to 100% or some where inbetween?
3. Does your lower value pwm duty cycle (say 50% duty cycle) send half the voltage (ie 24v) to the motor?
Thanks.
scd 6 years ago
2. 0 to 100%
3. In effect yes (due to capacitive filter effect).
Best Regards,
mahio4u 6 years ago
Thanks. How did you come up with the values for your capacitors? Was there a calculation? or you just chose available parts? How did you achieve the braking aspect? Did you stop the motor when you applied the brakes? Was there a stop switch..?
franganghi 7 years ago
Just a question. You oversized the components just to be sure to fit into your engine power requirements but cutting the power unit in two and using only one power diode and one fet but how much power do you think an alternative board would be able to handle considering
A. A good sw pwm implementation
B. current monitoring and consequent protection
C. Eventual spike current generated by the engine during start
I'm quite interested in developing a control board for an ebike engine but I'd like to understand if it is worthy first.
Thank you.
G
MattiV 7 years ago
i just orden 250W 24 volt motor my e-bike project and i think how i make arduino code speed controller whit FET and how i made over current limited here ? and then how control gel battery (2 12V serial=24V out) how code at NOT
over-discharged the battery ? how measure and protect battery. im not good write code to arduino.if somebody have working code and schematic i try made and test my project this. or have better use e-bike kit own controller ? but i think how safe battery not over discharge empty and think arduino whit i2c lcd can show battery volt,+speed+current+time+battery empty alarm,etc etc what must be.
varun1234 8 years ago
hello sir... i need the code for this... can u send it...???
scd 8 years ago
https://github.com/scottlbaker/DC-Motor-Control-in-AVR-Studio
Note: This code is incomplete and I have not worked on it or updated it in quite some time. Use at your own risk.
pavan60 8 years ago
thank u sir
pavan60 8 years ago
sir i need the code....if u have possible please send me the code
