DDR Dance Pad / Carpet in Wood
Introduction: DDR Dance Pad / Carpet in Wood
How to make a good ddr pad with some wood, copper foil, paint and a dead USB pad/keyboard
Step 1: Tools and Materials That You Need
As tools you need a saw, pen, meter , soldering iron and some good tape
As materials you need 80*90*1.3cm Agglomerated for the foundation, a 80 * 110*0.3cm wood use for the back of closet (it's a flexible wood)
- some screws and nails
- a broken USB pad or keyboard (with the electronic in working condition)
- some wires
- copper foils
Step 2: Let's Get Started !!
In first I suggest you to draw some lines on the Agglomerated in order to mark the emplacement of the spacer.
Then cut 10 pieces of 80 * 2 cm in the 3mm wood.
Step 3: Nails and Hammer
In this step you have to nail the spacer to the agglomerated with nails
Step 4: The Hard Part (if There Was One)
It's the most important step : you will scotch some cooper foil in the middle of each pad on the two part of the sandwich.
Step 5: Is It Finish ?
So now you have two piece of wood with some cooper and a lot of wire on it.
Go get them together with some screw !!!
And what to do with the wires ? well sold them in your USB "controllers" in place of the buttons for a pad or in place of some keys of the keyboard for a broken-keyboard.
Then test it and maybe you have to adjust the quantity of foam under the copper or maybe add some between the two layer wood because some buttons are always active it's up to you to tune it like you want.
Then paint it an go get some sport on stepmania !!!
Be the First to Share
    • One Board Contest
      One Board Contest
    • Fix It Speed Challenge
    • Photography Challenge
    14 Comments
    racer_x124
    racer_x124
    12 years ago on Step 5
    Great tutorial! I built one last night and the down arrow doesn't work :( Tonight I'll be playing DDR though!
    akz-p
    akz-p
    13 years ago on Step 4
    the wires you have running, say for the down arrow button, do I have to solder both the wires, from both sides of the wood on to the button?
    crazytiti
    crazytiti
    Reply 13 years ago on Step 4
    No, you have one for all and one for the button (except you have a strange pad) look at the PCB : each button have 2 wire but one is usualy connected to teh ground (sometimes to the plus) and the other go to the IC. you have to do teh same with the dance-pad, for me it's the upper part of the buttons thaht have been together and each down part is individually wired to the pad-controller.
    akz-p
    akz-p
    have you done yours via a keyboard? if so could you upload images, sorry this is my first time im creating anything for my pc, and to be honest im am totally confussed about the wiring, if you could it would be a great help
    crazytiti
    crazytiti
    lol, my advice is to always make a diagram on a paper first and THEN make it with wire ;)
    unfortunately meine isn't on a keyboard it's on an IC specifically program to be a windows-usb-hid pad.
    but i'm sure you will find tone of howto with you friend google because it's where i find this idea tested & approuved.
    you could lokk here too : https://www.instructables.com/id/Yet-Another-Stupid-Dance-Pad/?ALLSTEPS
    the main idea is to follow teh trace to four keys and then solder your wire on the keyboard PCB instead of the keyboard layer.
    Rustate
    Rustate
    13 years ago on Step 5
    Hey there I wanted to ask you if you could explain the keyboard wiring part cause I can't seem to get it
    super_r_85
    super_r_85
    Im Building up this pad for a festival, within 2 weeks, the pad will be used all day long with all sort of people jumping and playing on it, Do you think it will withstand the weights? another question, how did u soldure the wires into the keyboard? Thanks and u did a gr8 job :)
    crazytiti
    crazytiti
    Reply 13 years ago on Step 5
    I don't know if it's enought reliable to handle such "hardcore gaming" maybe you better have to replace my homemade switch by some "true" switch like this : http://www.conrad.fr/wcsstore/ConradImages/PRODUITS/1119964_p_g.jpg
    and drill holl under the pad.
    For the keyboard you have to follow the tracks on the flexible layer and then solder on the PCB connector where the flexible layer is connect :
    http://martybugs.net/electronics/images/leds_keyboard3.jpg
    super_r_85
    super_r_85
    Thank You for the quick Reply! I might make this pad to be used only in the "Happy Hour" not all day long after All! Cheers!
    barri_kid
    barri_kid
    14 years ago on Introduction
    This is not very clear. Having clear written instructions is very important. I can sorta understand what you are doing in the pictures. I have no idea how you are wiring it up to a USB keyboard. I tried doing that once, but the solder didn't stick. Also don't put the instructions in the yellow tag things in the pictures
    crazytiti
    crazytiti
    Reply 14 years ago on Introduction
    thank, it's the first DIY that I put on Instructables ;)
