DICE - a Tiny, Rigid and Superfast 3D-printer
32,068
259
35
Introduction: DICE - a Tiny, Rigid and Superfast 3D-printer
Hello!
My name is René, I am a 34 year old german electrical engineer and this is my very first instructable. In my spare time, I love to tinker with 3D-printers. In the last years I did build 3 different 3D-printer on my own, each (subjectively :D ) better than it's predecessor.
Now, for my fourth printer, I did it different. I wanted to build a good looking printer that is appropriate and small on my desk. And I wanted it to be top notch!
First, let me tell you a bit about designing and building the first prototype. This will cover a vast amount of reasons behind the design-choices and with all the following info, you can decide for yourself if this printer is top notch and if you want to build this, too. If you want to see the actual build-process, just jump to step 2.
Let's get started!
I already own a printer with a big buildvolume (bigger than 30x30x30cm) and because of the size, it needs a lot of energy and is rather slow. That's why, I started to plan a smaller printer back in october 2015. It was clear right from the start, that the new printer had to be small, precise and fast. Side effects of this would come automatically: less energy-consumption and easier handling in moving this printer around. On top of that, I wanted to build a printer that was beautiful too and assigned my priorities right from the start:
- clean look
- all parts inside the housing, even the powersupply
- use of high quality parts
- less than 20cm edge length
- silent!
- compact and fast
It will be my fourth printer - codename: DICE
With an overall dimension of exactly 20x20x20cm, one could really speak of a small dice. During the design and build of the DICE, I was able to consider all of my priorities - this was less easy than I had expected.
Now to the key features:
mechanical:
- casing: 20x20x20cm small
- buildvolume: X90 Y75 Z 80
- moveable distance: X98 Y75 Z80, so the printhead can move beside the printbed, e.g. for anti-ooze-scripts at printstart
- coreXY-system
- linear movement with high quality linear rails (HIWIN MGN9R) in X, Y, Z
- full metal hotend E3D-V6 1,75mm in bowdensetup
- PEI-coated perma-printbed made out of precission-milled warmcasted aluminium ( EN AW 5083 ) and recessed silicone heater
- direct-drive-extruder (MK8)
- massive enclosure milled out of 4mm thick akuminium, all bores in DXF included
- XY-plain is lasercutted out of 2mm thick stainless steel sheet, all bores in DXF included
- enclosure-sheets are conceived as load-bearing and stiffing parts, but can be dismantled all together without the printer falling apart.
- all parts are designed in a way to make adjustings easy and the components inside accessible.
- all parts are designed to use only one needed manufacturing technique (lasercutting) and are repeating and symmetrically
electrical:
- AZSMZ-mini 32bit-controllerboard with smoothieware firmware
- 4x most silent TMC2100 stepperdrivers, passive cooled
- despite the small footprint, use of full-fledged NEMA17 steppermotors for sufficient output reserve
- heated bed (230V / 60W), with recessed silicone heater
- motor supply voltage: 19V
- total power input: 230V / 0,65A at max
miscellaneous:
- more silent than 40dB in realistical and normal operation (unadorned measures!)
- up to 833mm/s travelspeed
- up to 12.000mm/s² acceleration
- not until 10.000mm/s² acceleration and 100mm/s, ghosting becomes barely visible
- junction deviation up to 0,5mm tested
- the complete X-carriage (real print-setup) weighs only 160g
- the complete X- and Y-carriages with all mounted parts (real print-setup) weighs only 290g
- Hotend mounted with 2 screws, fast interchangeable
- bowdenlength is only 35cm (complete from MK8 to the thermal barrier in the hotend)
To design the DICE was an unexpected experience and I had a lot of fun. The permanent challenge to get every detail perfect and to reach a valuable compromise in every aspect, still with the priorities in mind, was thrilling. On one hand, I had to make every part and every space as small as possible to reach the maximum buildvolume. On the other hand, things need to be convenient and accessible for maintenance and construction. On top of that, it should stay simple and with a clean design.
To reach all this, I did a vast number of designs for every part and sometimes started with a finished part all over again, when another part comes into play. I had a big advantage in using my existing 3D-printers. Its one thing to design a part in a CAD-software, but it is the complete other side to hold this part in hands and try if it works. In my mind, the most challenging part to design was the printhead / X-carriage. The size of the carriage had a big impact on the later buildvolume. Every millimeter saved at the carriage was gained in more buildvolume immediately.
With the compact printhead, the desired buildvolume of 8x8x8cm was reached. Just when in need for print-cooling, like for printing e.g. PLA or PETG, I have to pass on 5mm buildvolume in Y-axis. The previous planned coolingfan with his 30mm-formfactor didn't make sufficient cooling and had to move for a more powerfull, but bigger fan with 35mm formfactor. If not in need for print-cooling, a fast and simple change brings back the full buildvolume.
The remaining measures of the DICE were much easier to handle. They come from existing parts and if the part is moving, I added a "generous" 1mm gap to avoid grinding. Simply said: I worked myself from the outside in.
For example, the height of the XY-plain is exactly 38mm. This is apparent from two facts: The motor of the z-axis is a shorter NEMA17 with 34mm length, with 2mm sheet on each side. Without a recess for the motor-body, no smaller distance is possible.The smallest possible assembly of one Y-carriage with flange-bearings is exactly 33mm (I tried this several times) and allows for 1mm gap for the movement with the 2mm sheet on each side. I even use the smallest possible flange-bearings. The limiting part with this is the GT2 belt. The belt is 6mm wide and two MF104ZZ-flange-bearings have a runningsurface of merely 6,4mm. assembly of the XY-plain with miniature flange-bearings MF104ZZ
With the 38mm top plain given, I made it symetrically and used the same 38mm height for the electronic compartment at the bottom. I needed to find a power supply that fits inside and is able to deliver up to 60W (so I need 90W because rule of thumb: don't use a powersupply at 80% or more of it's size). All popular affordable industrial power supplies in the needed powersize had too much design height. And all racking controllerboards, like RAMPS or RADDS are oversized, too. The GT2560 and the AZSMZ-mini have been shortlisted for mounting.
Short before, I had the occasion to try out a Smoothieboard and because of this the decision was easy: I picked the smoothieware-compatible 32-bit-board AZSMZ-Mini. Who once experienced smoothieware with it's ease of use and drag'n drop functionality, knows what's good and will never change back to repetier or marlin.
Although stacking the stepperdrivers (TMC2100) with it's rather big heatsink was possible and would have fitted inside, I did take another path. With the use of the conventional heatsinks, I still would have had to use an active cooling and if you look closely on the picture above, I already designated two 30mm-fans for this. But I wanted to avoid additional soundsources and thought about cooling the stepperdrivers passively.
I put all stepperdrivers on the thick sheet right beside the controller-board. Because of its size, the 4mm thick sheet is an impressive heatsink.
After hours of testing without loosing steps, I was sure that the stepperdrivers stay cool enough the whole time. But I still have one fan operating: it's a 12V-one connected to the 5V-rail and therefore inaudible operating. This makes a small airflow for the powersupply and the controllerboard, just in case. Additionally, this small airflow reduces the temperature of the "heatsink" drastically. And needed or not, the CPU on the AZSMZ-mini got its own nice heatsink.
This two 38mm high, horizontly plains leave exatly 124mm room for vertical movement of the z-axis. Deducting a carriage-length of 29mm of the linear-carriage (MGN09CZ0M, Hiwin), I ended with 95mm possible Z-stroke.
One need to consider, there is additional room needed for the printbead-adjustment and depending on the mounted nozzle, there are even some more millimeters needed. The planned printheight of 80mm left enough room to design the adjustment for the printbed generously. Additionally, I could lower the hotend a bit more, to get it more "inside" of the printer itself.
The back of the DICE is exactly 51mm thick. This is the exact size the mounted NEMA17 need to fit in, not more. The touching sheets are functioning a bit as additional heatsinks, the motors do stay cooler. If you look closely, you will recognize that there is no clutch on the z-axis. Because of reasons of space, I used a motor with integrated spindle, a TR8x4. Beneath the 3 motors for the X,Y and Z-axis is enough room for the extrudermotor and the 230V-plug with integrated switch and fuse.
The NEMA17 in the pictures represent a good size comparison for the size of the DICE. Remarkable is, that all mounted steppermotors are mounted in one plain and are located right beside each other. Even the extudermotor is mounted inside and only peaks outside with its shaft. On the outside, I mounted the most compact Extruder I know about. The author of this design did respond to my needs and made some changes on his design for me. That's why I could mount the best possible design.
The extruder is a printed one with an MK8-gear and made for 1,75mm filament. This extruder is used on all my 3D-printers and I am very pleased with it. Super simple, super cheap to make and super reliable.
If dismounting all of the cover panels, the inner frame is still able to hold everything in place. This makes any maintenance or adjustment very easy, even in this tiny printer every part stays reachable.
The printed parts could also be made out of aluminium, which I did to get an even more quality build. A further remarkable detail is the independent XY-plain. The whole assembly of the X- and Y-axis is mounted between the two lasercut stainless steel sheets and because of the given mountingpoints, the linear rails just fit in place with little to no further adjustment needed.
Step 1: All Needed Info Packed Into 3 Dense Packages
The tiny DICE is now ready for rebuild. I did a few small but meaningful changes, so that the DICE is fun for everyone. So was waived the mains voltage of 230V in the printer and changed to protective low-level-voltage of 24V. In addition, the print-bed is simpler and the connection is improved. With the relocation of the power supply to the outside, there is room for a Raspberry Pi in the printer, now!
And in addition to this top notch 3D-printer, you get step by step tutorial videos. With nearly EVERYTHING explained ;) Therefore, I disassembled the DICE and rebuild it while making videos and explaining stuff.
First, you need to download the needed source files here: [dropbox folder]
Then, take a look at the BOM (bill of material) at [google docs]
Last, lean back, relax and watch the build step by step via a [youtube playlist]
The videos are in german, but I'm working hard on completing english subtitles!
Oh, and in case you like this project, you maybe want to vote for it. Thank you!
Step 2: Preparation: Lasercutted Parts
Watch the video and inspect all lasercutted parts for a burr of the laser. In case, remove it with a file.
Step 3: Preparation: Linear Rails
If you have HIWIN linear rails, you need to grease them.
If you have Misumi linear rails, you can ignore this step. Misumi carriages are pre-greased and ready to use.
Step 4: Preparation: Slit-nuts
The slotted-nuts may be a little to big to mount into the rails, so in case you need to sand them down a bit.
Step 5: Preparation: Silicone Cover
Get a silicone cover for the heaterblock. It's really worth it!
Step 6: Preparation: Printed Parts
Print or mill the needed parts.
Step 7: Preparation: Z-motor
Shorten the spindle to something between 140mm and 160mm, grease the nut and make the wire at least 40cm long.
Step 8: Preparation: Controllerboard AZSMZ-mini
A little explanation on the controllerboard. Get V2.1 of the board and an SD-Card.
Step 9: Preparation: Wire Management and Connectors
What do you need to know about wiring in the DICE.
Step 10: Preparation: Print Bed
You need either a PEI-coated Aluminium sheet or something like buildtak for adhesion.
Step 11: Mount the Linear Rail of the X-axis
Watch the video and follow the instructions given.
Step 12: Mount the Printed Parts on the Y-carriage
Step 13: Mount the Linear Rails for the Y-axis
Step 14: Combine the X and the Y - Axis
Step 15: Mount the Flange Bearings on the Y-carriages
Step 16: Mount the Lid of the Y-carriages
Step 17: Mounting the Flange Bearings to the Frame
Watch the video and follow the instructions given.Watch the video and follow the instructions given.
Step 18: Mount the X, Y and Z-motor
Step 19: Combine the Xy-plane
Step 20: Glue the Belt In
Step 21: Mount the Vertical Pillars
Step 22: Mounting the Z-sheet
Step 23: Mounting the Z - Linear Rail
Step 24: Mounting the Printbed Holder
Step 25: Mounting the Bottom Sheet
Step 26: Mounting the Fanholder for the Electronic
Step 27: Combination of Parts
Step 28: Tension the Belts
Step 29: Mounting the Print Bed
Step 30: Mount the Extruder
Step 31: Mount the Hotend
Step 32: Solder the Hotend-wire
Runner Up in the
3D Printing Contest 2016
First Time Author Contest 2016
35 Comments
Question 3 years ago
would it be possible with the files provided to increase size so the printing surface is larger
4 years ago
The Dropbox link doesn't work for me
Reply 4 years ago
visit well-engineered.net for information. This instructable is not maintained.
4 years ago
Dude :D das Teil ist so genial. Was waren deine Kosten? und Mega wie detailiert du hier die Anleitung gemacht hast ! :)
5 years ago
Hi!
Congratulations on the great design and instructable!
I love your design, but I do not have the budget, so I am trying to put together a cheaper version of it..
You chose the AZSMZ controller due to size restrictions, but would a RAMPS work as well? It is significantly less powerfull and I have never used it in a coreXY configuration. Do you think it would be appropriate? have you ever tried it? (I have seen some people online complaining about firmware problems when dealing with coreXY and RAMPS)
Many thanks and keep up the good work!
5 years ago
This is a beautiful bit of Engineering. You should consider selling kits - I'd buy one!
Reply 5 years ago
You can buy nearly everything you need at youprintin3d.de -> printers -> DICE
They even mill out the needed parts for you, just write them an email...
5 years ago
what you have done here is simply amazing! thanks for sharing
5 years ago
I really love this design, so much that I just started looking into the BOM to see what I would have to buy to build one myself.
I haven't looked at all parts yet, but I noticed that the specific linear rails in the list seem to no longer be available. I'm not experienced with linear rails, but I suspect the "Misumi MGN9R120" could be replaced with any 120mm long MGN9 rail (like this: https://www.aliexpress.com/item/CNC-9mm-Linear-Guide-MGN9-L-120mm-linear-rail-way-MGN9C-linear-carriage-for-CNC-X/32733035851.html?ws_ab_test=searchweb0_0,searchweb201602_2,searchweb201603_1&btsid=3cffd10e-28a8-4d5c-96a0-2e46c983eaac), and 150mm for the other one?
Reply 5 years ago
Hi! The link in the BOM is still working: https://youprintin3d.de/3d-drucker/dice-der-edle-m... I can recommend genuine misumi and hiwin linear rails, and not recommend the knockoffs. I have several knockoffs at hand and all of them aren't even close to the genuine ones. On the other hand, it is only 12€ to throw away if they are bad, so, you decide.
Reply 5 years ago
Ah, the link is just to the store front, and neither "Misumi" nor the part name is searchable in the store, but the part is obviously still sold. :)
Thanks for the input, I'll think about how I will approach this.
5 years ago
Hi, don't see micro switches for the XY gantry. How do you manage to know the starting position? I'm working on my own hobby project which also uses the core-XY gantry.
I see some great other solutions which I haven't thought of before, thanks for the inspiration!
Reply 5 years ago
There is no XY-home-switch. The printhead has to be moved by hand in the front left corner. The print gCode then starts with a G90 X0 Y0 to set this position to the home position.
5 years ago
Hallo René.
I have downloaded your dxfs and I see that the dxf for the bodenplatte is different than the one in your video; the video version having a lot more holes for ventilation. Do you have an updated version to post?
Danke,
Jason
Reply 5 years ago
The plate shown in the videos is from my first prototype. The more holes are needed, because i did put the powersupply into the bottom compartment. In the final version (what the available files are) these holes aren't needed.
6 years ago
This is by far one of the most detailed and planned out builds I have seen on here. I love it, keep up the good work!
Reply 6 years ago
Thank you! The dice is made out of blood, sweat and tears ;)
6 years ago
This printer is just as beautiful as a true italian coffee machine -- I'm completely amazed by this and by the phenomenal video instructions.
Wahnsinn, so gute Arbeit zu sehen, in der Konstruktion und der Dokumentation :)
Reply 6 years ago
Danke für die nette Worte!
Reply 6 years ago
The similarities to the coffee-machines are not intended :D I didn't even know about them until just 2 monts ago...
