Introduction: DIY : Eggstractor
Very useful way to peel an boiled egg. With this homemade gadget you can peeling over 50 eggs per minutes . Very Very Fast and Easy. Great for introducing kid to the science.
0})]]
Step 1: The Box
take a solid box.wood or plastic or metal.its your choice.
Step 2: Box Hole
make a hole little bit bigger than the egg.and add rubber (balloon) for more grip.
Step 3: Air Compressor
take a plastic tube with a diameter a bit bigger than the egg.Make 2 hole.a bigger hole for the egg and smaller hole for the air compressor stick.
Step 4: Buils an Air Pump.
For compressing air .build this pump.Make sure it is very tight
Step 5: Push Button
make your favorite push button
Step 6: Hole in Box and Diameter of Compressor.
plastic tube should be bigger than the hole in the box
Step 7: Now You Are Ready
make 2 hole on both end of the egg and place your egg in the box hole.and push hard .
voila . a perfect peeling boiled egg machine.
50 Comments
8 years ago on Introduction
just mount a small nail on the side of the box for easy pricking on both sides of the shell before putting it into the rubber, hey presto! no searching for a nail every time.
also if you make a small 'ramp' within the box the egg can roll out onto a pre placed dish or something and stop you having to open the top each time to grab your egg.
15 years ago on Introduction
I still do not understand how it works. Why is the rubber needed on the box? What happens to the shell? Where does it go? Why do you have to poke holes in the egg? I could peel fifty eggs in the time it would take to build this.
Reply 15 years ago on Introduction
The Rubber is there to seal, so no air gets out, and to hold the egg in place. Nothing happens to the shell, watch the video again, its still there. The hole on the top is for the air to go in, the one in the bottom to ruin the structural integrity of the eggeshell, and give the pressure a place to go. Nice that you can peel those 50eggs... Maybee this device will hit the market sometime, so you don't have to build it. Over time, this device will be more efficient then you peeling them by hand. Just imagine, you spend 30 Minutes building this. And don't ever have to peel an egg again...
Thanks. So you just clear the shell from the rubber and place another egg and you are ready to go again?
Thats exactly it. Clear the shell, and your good to go for another egg. So in the End, its a bit faster then by hand, but at least easier. I often tend to get the eggshell between finger and nail when i peel them....
Reply 13 years ago on Introduction
i remember when we studied about the time when japanese invaded the philippines.....
...... they torture us Filipinos by putting pins in between the nails
So i guess eggs are invading your kitchen....
LOL!
Reply 12 years ago on Introduction
im a filipino too!
you mean peel an egg by hand?
What about the shells? Are they still usable after extracting the egg?
Step 1: Cut a hole in the box. Step 2: Put your egg in that box.
free cream and ketchup dip and sausage with every 2 eggs LOL
I was thinking that exact same thing - and my dirty mind had all kinds of thoughts about that video....
50 eggs per minute? I guess if you had 50 pre boiled eggs, and had pre-punched the holes, you might be able to get away with it. It does look like it is useful, however. What if you found a way to put a pin or nail or something in the end of the plunger? You could use that to pierce the egg, then pull the plunger all the way up and pump down. No need for scissors.
would need really long nail though, ti puncture teh egg from top to bottom :(
No! Short little tiny needle, just enough to get through the shell. Poke on one side. Flip. Poke on the other side. Then put it in the thing.
that can be done too :) i thought you meant a needle, just to go trough the shell, egg, yolk, egg and shell again, not just shell, turn shell :P
or use a drill press! lol
cool-hand luke
lol, im glad someone else was thinking that.
