DIY $5.00 Sandblaster
1,042,062
1,344
444
Introduction: DIY $5.00 Sandblaster
About: Instagram: withered_perception
Instagram: Withered_perception
I have some rust on my driveway and some old rusty tools I got from my grandfather years ago.
I have been looking at sand and soda blasters for about 6 months. They are either inexpensive and cheap or very well made and expensive!
So I decided lets just make one.
Step 1: Get Crap
Go get some crap at Harbor Freight. This air gun kit ran $4.99.
Now find a bottle in the trash.
Step 2: Say "Hi" to the Cat
This optional but important step may be the difference between you succeeding or failing.
Step 3: Cut the Neck
Remove the locking neck for the cap.
Step 4: Drill
Grab a 3/16" bit and drill the neck just under the cap.
Step 5: Test Fit
Push the air rod in. It should be very snug!
Step 6: Mark
Mark the bottom of the air tube. Spin the tube around so you can hold the handle while you file.
Step 7: File
File a hole through the tube to let your media in. When you're done spin the tube back so the opening is at the bottom.
Step 8: Fit
Get the tube back into the hole.
Step 9: Seal
Not looking for the glue to actually stick here.
Just looking to prevent the hole from opening up too much while under pressure.
Step 10: Test Blast
Put your Saftey goggles and gloves on and give it a good blast. I shot at the rust on the drive way and removed a spot (the white part) in just a few seconds.
I will give you an update on the driveway once I have time to do some actual blasting on it.
Step 11: Real Deal
An old set of needle nose (rusty as hell...)
Step 12: Blast Away
Clean as a whistle!
Step 13: Extra Step
Because everyone keeps asking this is my air compressor a California Air Tools 10020c running at about 40 PSI for blasting.
I also use 20/40 crushed walnut for my media.
For PPE I use gloves, a P-100 respirator, long sleeves and a face shield. No excuses! Do not mess with your Safety!
[Play Video]
5 People Made This Project!
  • Build a Tool Contest
  • Meatless Challenge
    Meatless Challenge
  • Sculpt & Carve Challenge
444 Comments
Peale
Peale
Question 1 year ago on Step 13
So far...it hasn't worked. I'm still working out the kinks.
I decided to use playground sand. First mistake was having it be a bit damp. Second mistake was not sifting it for larger chunks.
After sorting those two issues....nothing. I'm not sure what I'm doing wrong. The bottle pressurizes, and very little, if any, air makes it out the nozzle.
How large of an opening needs to be cut in the tube?
Quandur
Quandur
Answer 1 year ago
Damp playground sand will not work. Air pressure has a positive force to the handle of the gun and only releases when the trigger is pulled. Your bottle shouldn't be pressurizing; air pressure is entering and exiting the nozzle, gravity feeds the blasting material into the cut slot of the nozzle, blasting material exits nozzle.
If your bottle is pressurizing, your nozzle is clogged.
Quandur
Quandur
Answer 1 year ago
Amazon
RiekieMJMW
RiekieMJMW
Answer 4 years ago
in 1975 a Diesel mechanic show me an engine overhaul and that was one of the things he did - the less force you use the better preserved the items are
DubbieH
DubbieH
Question 2 years ago on Step 12
Where do you get the blasting media?
Quandur
Quandur
Answer 1 year ago
Amazon
Apk0605
Apk0605
2 years ago on Step 2
This is a very crucial step in this process. Of course if you have dogs make sure you say hello to them as you would a cat. Yes.
KellyCraig
KellyCraig
3 years ago
Very clever. I think I'll build a version and keep it in my sandblast cabinet for specialty work.
santaemmett
santaemmett
Question 3 years ago on Introduction
Where do you get 20/40 crushed walnut shells?
RobW140
RobW140
Question 3 years ago on Step 13
hi, have you baking soda with this blaster? how effective was it?
Gunsaw
Gunsaw
3 years ago
Everyone here making this instructable should understand that the P-100 filter mask is A MUST! If you use beach sand, play sand, ANY KIND OF SAND! understand that you are risking getting silicosis. Breathing the vaporized sand from blasting can and will kill you slowly and painfully after it sets in months or years later and there is NO CURE!
Gunsaw
Gunsaw
Reply 3 years ago
Also note that using sand specially made for sand blasting has a greatly reduced silicosis risk. And remember that this device has no ceramic tip so it has a limited number of uses before the sand sand blasts the air tip into oblivion.
Nikiniku
Nikiniku
4 years ago
I was wrong about being able to buy a complete sand blasting kit for $29. I discovered that when went to Amazon just now to buy it. $29 does NOT include the compressor. As far as the kits NOT INCLUDING COMPRESSORS are concerned, the cheapest one I could find was $11.95, and there were nine less than $19.00. The compresors I found were not that cheap. There was one for $13.95, but the next highest one was $19.95, and they went up from there. So, it looks like I won't be buying a sand blaster and compressor to clean the surface of my concrete driveway. I'll have to stick with the power drill and circular sandpaper discs I have been using.
Gunsaw
Gunsaw
Reply 3 years ago
pressure washer is best.
offramp
offramp
Reply 4 years ago
ummm.... have you considered muriatic acid...?
