Introduction: DIY Ambient Lighting With Hyperion. Works With HDMI/AV Sources || Raspberry Pi
This is an expansion of my previous Ambient Lighting build. Take a look at it first:
https://www.instructables.com/id/Build-your-own-Amb...
This time I will add a new function to my DIY Ambient Lighting. Until now It only works with the Raspbmc software. That means that I can not add Ambient Lighting to my PS3 or cable TV. That is about to change.
Step 1: Watch the Video!
The video tells you all important steps that you have to follow to make this build happen.
Step 2: Order Your Parts!
Here are the components with example sellers that I used. If you buy exactly the same ones then it should probably work for you as well (affiliate links):
Amazon.de:
BIGtec USB 2.0 Audio Video Grabber: http://amzn.to/1sXPKst
HDMI Splitter: http://amzn.to/1sAL86B
HDMI 2 AV Converter: http://amzn.to/1jQlcDE
Aliexpress:
USB Audio Video Grabber:https://s.click.aliexpress.com/e/_dXcU4Vk
HDMI Splitter: https://s.click.aliexpress.com/e/_dZeoBCe
HDMI 2 AV Converter: https://s.click.aliexpress.com/e/_dTvJTPk
Amazon.co.uk:
USB Audio Video Grabber: http://amzn.to/1EOxvJC
HDMI Splitter: http://amzn.to/1RaA3rZ
HDMI 2 AV Converter:http://amzn.to/1GNaxRj
Step 3: Download the Software!
You can download the Hyperion configurator directly from here.
But you have to download the img. file (513MB):
Step 4: Download the Android App!
It is really awesome to use those WS2801 LED strips as a mood light.
And the Android App makes it so much easier. So go ahead and download it. You can also buy the 1$ app to support the developers:
Step 5: Success!
You did it! Again! Congratulations to your second Ambient Lighting Build. I hope you enjoyed it.
Feel free to check out my Youtube channel for more awesome projects:
http://www.youtube.com/user/greatscottlab
You can also follow me on Facebook, Twitter and Google+ for news about upcoming projects and behind the scenes information.
5 People Made This Project!
- dhaval0603 made it!
- JosephH48 made it!
- david.holmberg.33 made it!
See 1 More
208 Discussions
Tip 3 months ago
Be careful. The HDMI2AV item linked in Ali Express is actually an AV2HDMI converter. I think this is what you actually need: https://www.aliexpress.com/item/4001120099582.html
The tutorial and idea are awesome! Top fan here!
Question 1 year ago on Introduction
Hello Scott,
Could you please share which HDMI splitter will work with your solution with support of 4K and HDR? Thank you a lot.
2 years ago
Do both ends of the LED strip need to be connected? From the tutorial I would say no but this source clearly shows the opposite.
https://hyperion-project.org/threads/raspberry-pi-...
The LEDs can just turn red for some reason...
3 years ago
How can I tell if my video grabber has the correct chipset for the raspberry pi?
3 years ago
Hi,
What do you thing about using HDMI to USB adapter ? Isn't that a little better solution as giving us one adapter less?
3 years ago
Riddle me this. Can I do this with out setting up raspbmc ? I already have a HDfury device that can split a HDMI signal so this should be easy to work with.
3 years ago
hello...
I moved the file with Win32DiskImager to my sd card and put to the RPI3 ,nothing happens.
I did the same thing with a OSMC ,RPI3 Turn on.
What to do ?!
3 years ago
Hey guys i wanting to make this for my PC dual monitor setup.
just wanted to know that do i need exactly this same components sine it will be connected to my PC not TV?
Reply 3 years ago
Not sure if this will work with multiple monitors... you would probably need to double the quantity of all of the parts listed and set them up separately on each screen..
Reply 3 years ago
I would think that his two monitors are just treated as one (with higher resolution). So he would need to treat them as one. The main issue would be wiring between his monitors.
He would then make the width strips the total width of two monitors and cut them, then resolder with some wire that is hot pluggable maybe. This project might work best with some sort of desk mounted monitor holder that holds both the monitors, or wall hanging them.
Reply 3 years ago
That's a really good point to make, one that went over my head. I have a triple monitor set up, but I treat each monitor as its own.
Thanks for the insight (might have created a future project for me, thanks)!
3 years ago
Hi Scott
Great tutoria. I'm tryng to do it. But, I don't have an android movile phone. Could I do it with an iPhone?
3 years ago
hi all.
i've tried building this today and it appears that the usb capture card listed in the video doesn't have the right chipset to work on the pi. does anyone know somewhere that i can get one with the right chipset? ideally in the UK?
4 years ago
Can you use Kodi with the RPi as usual?
Wonder if when you are not using Kodi and then have a console active, wont the ambilight get in conflict with another device? for example a console?
Or is it only possible to use this RPi for ambilight only?
4 years ago
Can there be any HDCP problems when using Netflix from FireTV or something like that?
4 years ago
Also where are the led light strips?
4 years ago
Is this a good Pi? https://www.amazon.com/CanaKit-Raspberry-Complete-...
if not could you recommend one?
4 years ago
You can use OpenLec or OSMC with Raspberry Pi 2's and install Hypercon from there.
Once installed, ssh to the Pi and paste the following...
curl -L --output install_hyperion.sh --get https://raw.githubusercontent.com/tvdzwan/hyperio...
sh ./install_hyperion.sh
4 years ago
I don't know if anyone else has seen it, but somebody did this project and crammed it into a box. I plan on doing the same with the housing of an old 20-port Ethernet Switch enclosure and a PC PSU. I have drawn up a schematic, including all the parts/pieces needed to enclose the entire project (minus the enclosure and PSU). Thought it may prove useful for the public to share!
http://schematics.com/project/ambilight-box-32568/
4 years ago
Please help..
I have raspberry pi 2, did everything in this guide but can't make it work :-(
Does anybody got it to work?
Thanks
