Introduction: DIY Bonsai From Small Tree
What you will need..
Small tree (fig, maple, cumquats, pines, are most common)
(I have used a miracle fruit tree, don't use a tree that has large fruit, they won't grow smaller.)
Bonsai Tray
Vermiculite
Soil
Strong Scissors or garden shears.
Bendable wire (copper or aluminimum) Preferably 2 different sizes.
Large one to anchor plant, smaller guage wire for branch training.
Small rocks
Coco Palm Fibre or fly screen
Optional Spagnum Moss & larger rock for placement on top
Step 1: Lets Start With the Bonsai Pot
Cut Coco Palm Fibre or Fly Screen to size that fits the bonsai pot.
Making sure it covers the draining holes.
Then Lightly Cover with small aquarium rocks.
Step 2: Digging Out Your Tree
Dig out the tree.
Wash as much soil from the roots as possible with the hose.
Trim roots, basically anything under 1.2cm in diameter can be cut,
two thirds to three quaters can be removed,
leave mostly large roots basically, but even they can be cut back a bit.
See pictures
Step 3: Anchor Your Plant
Starting at the top of ur plant following the main stem down, wind the wire around the stem and partially around the roots, then poke it through the layer of rocks and coco fibre and hole,
pull wire through until it sits how you want. (straight, lean, even cascade if you like.)
Step 4: Nearly Done
Okay assuming ur anchor is hooked in over the lip of the pot.
Fill with a 50% soil and 50% vermiculite.
Water with a very fine mist, i use a spray bottle.
Twice in summer, else once a day.
Morning sun only for first few weeks, don't bring inside for more than 2-3 days straight.
Place Sandstone rocks (optional)
Place Spagnum Moss on top, also optional.
Wire any other branches if you want them shaped differently.
Step 5: Prune the Plant
Basically cut off any large leaves.
And Repeat when its older.
Depends of species of tree your working with.
6-18 months rough.
Hungry Scientist Contest
Craft Skills Contest
