DIY Cardboard Cutting Machine - "The Bibbler Nibbler 1000"
Intro: DIY Cardboard Cutting Machine - "The Bibbler Nibbler 1000"
I wanted something that was fun for my kids (9 and 10) to use to make things using cardboard as an input. We have a lot of Amazon and other shipping boxes that we typically throw away. At a Philly Makerspace event last year, my younger son spotted an interesting exhibit that used a nibbling tool to cut cardboard, and pulled me aside and said, "Dad, could you make something like that?" I thought about it and "The Bibbler Nibbler 1000" was born.
Note that with all mechanical and electrical things, adult supervision is needed. The nibbler cutting unit itself has very little clearance (~2mm), but enough for cardboard to fit in. Although it's unlikely a kid's finger would get caught (it's hard to shove it in there), reasonable care should be used when using this machine.
Attached are some pictures of projects my kids and I worked on to give a sense of what you can do with this cool machine. Also, some pictures of my son, and other kids using it. We had an exhibit at the Bergen Makerspace (Hackensack) on New Jersey Makers Day (March 25, 2023).
STEP 1: Disassemble Drill
Disassemble the drill as much as possible but retain the motor and chuck. If you have adjustable settings, you might want to turn the adjustments to the strongest settings (this controls the planetary gear settings in the gear housing). This step is important because you don’t want the planetary gears to skip once the nibbler encounters resistance (which it might if you used the “screw” driver setting). Cut the plastic housing out but retain the gearing. Make note of the settings and how to adjust the drill in the event something comes loose. Measure and create the clamping system using the Fusion 360 files. If you have the DW991 14.4V drill, then you can use the attached 3d printer files.
STEP 2: Nibbler Unit
Determine the size of your nibbler unit. If you bought the suggested one, then the attached 3d printer files should work. Slice the file with a heavier density (I used 20% fill and heavier walls--sorry there's a file size limit on the uploads so I cannot attach the STL file). I’ve also attached the Fusion 360 and STL files in case you want make changes. Note, you should check the orientation of the nibbler unit itself (see picture) as I found that when the cutting bit was screwed into the main nibbler base, the orientation of the cutting bit was angled off-centered and would mean you would have to mount the unit onto the underside of the work area off-centered. I ended up returning the first nibbler, and the replacement had a better orientation.
STEP 3: Top Plate
Cut out the top plate pieces. I used a 16” x 24” dimension which turned out ideal for the kids. It’s small enough for them to manage, and big enough to maneuver cardboard feedstock. Note that the nibbler has an exhaust area for the waste to come out. I used 2 pieces of hardboard for rigidity (see picture), but also allowed space on the bottom sheet to allow the waste material to exit. Note that both hardboard pieces sit directly onto the box frame and are not recessed into the box frame. I wanted to ensure that no cardboard would catch an edge, so the entire top is clean. Attached are a print out of the Lightburn files (Lightburn is not supported on this platform) that take this into account. Blow up the orientation to whatever size you need them.
STEP 4: Marking Out Clamp Holes on Top Plate
Take the 3D printed clamps and make sure they firmly hold the nibbler and the drill motor/chuck and lay this out on the top plate to determine appropriate orientation and placement. Once you are satisfied with the placement, mark where to drill the holes to attach the units to the underside of the top plate. Clamp the two top plate pieces together, in the expected final orientation, and then drill. You’ll need to countersink the top-most hole to allow the screw heads to be below the surface so that the screws don't catch the cardboard. Do this for all the holes on the top-most plate.
STEP 5: Making the Box Part
Cut out the sides of the box. If you are ordering the variable power supply I listed, then the sides of the unit will need to be at least 5 ½” to clear the PSU and have enough space to put in a notch so that you can slide the optional base plate (which is handy to keep the copious waste in one place). For the front panel, you'll need to cut the front horizontally if you want the bottom plate to be slide out from the front. I did this by eye and secured the top to the bottom box pieces, making adjustments along the way, and then screwed each bottom box panel to each other, but that’s my approach because I wanted to be sure the bottom edges matched the length and width of the top panels. You could easily make the bottom and then secure the top onto it.
You could either pre-cut out the holes for the module plug and the male 3 pin socket at this point or after the box walls are attached to the top plate.
Also,
STEP 6: Electrical
See the pictures on the wiring. Also, see the transformer spec sheet and the hand drawn wiring diagram to connect the power supply with the various components. I'm showing the module plug backside so you can orient the wiring to the transformer PSU. Notice that the peddle is a simple switch on the actual PSU output, so that there is no delay on starting the drill; otherwise if you put that switch on the live wire from the outlet then there's an annoying delay because the PSU needs to charge up before the right voltage powers the drill. That was an upgrade that my kids approved of. However, note that this means that even if the peddle is not depressed, there is current flowing to the PSU, which is why the module plug has a separate rocker switch to shut off the power to the PSU.
You might want to secure the PSU to the box using clamps. See the Fusion 360 and stl files attached.
Note that the PSU comes with a control to adjust the power to the unit. I adjusted mine to be ~20 volts because I couldn't find the motor specs, so I did it based on judgment. I didn't use the optional control to be outside the box because I didn't want the kids to fiddle with it. Just set it to ~20 volts and move on. If you need a little more "umph", then push it to 24 volts, but note that it may shorten the life of the motor.
STEP 7: Foot Pedal
Here's the optional foot pedal-switch. I decided to just go with a simple on/off switch version (instead of the adjustable) as I didn't want the kids to fiddle with the speed. You’ll need to cut the computer power cord male plug end and wire it to the pedal (see picture). If you go this route, then consider tying a knot in the wire in the pedal box (see picture) so that if the main shielded cord is pulled, it doesn’t disconnect the wires from the foot pedal switch. You'll notice that the green wire is bent down because the pedal is merely a simple switch.
See the picture of the metal plate connected with 2 screws to the pedal spindle. At the Bergen Makerspace presentation, the unit was heavily used and then stopped working (there were unhappy kids involved, but this was "battle testing"--Thanks Carl for the term!). At first I thought it was the motor overheating, or the PSU pooping out, but it turned out to be the pedal switch. The metal bar was bent from the usage and stepping on the pedal didn’t move the internal switch enough to allow the electricity to flow. I just needed to re-bend the metal plate to fix the problem, but I'll keep that in mind in the future. I would still go with this unit as it seems the sturdiest of the various ones on Amazon.
STEP 8: Potential Upgrades
I'm thinking of venting since I used PLA to print the motor/nibbler mounts. If the unit is heavily used, then the motor will heat up and potential deform the mounts. If I do this upgrade, then I'll likely install a fan with a power adjustment. Another upgrade might be to print the mounts with more venting holes to allow more airflow. These are just some things for you to think about. Let me know if you have any other upgrades.
STEP 9: HAVE FUN!
Your kids will really enjoy playing with this. It'll become part of the house tools that the kids will set up and use, especially when other kids come over! I'm hoping this inspires them to work on something for Halloween!
9 Comments
kenmiao01 2 months ago
I've made a smaller version: 12" x 16" with some improvements (colorful paint job, polycarbonate top, LED lights, and a variable motor governor). It's more exciting for the kids, but I'm still tinkering with it because the polycarbonate is acting as a resonance board (speaker) and amplifying the sound. Maybe TPU as a motor mounting material?
kenmiao01 7 months ago
Buck circuit: https://www.amazon.com/gp/product/B076H3XHXP/ref=p...
Indicator light: https://www.temu.com/goods.html?_bg_fs=1&goods_id=...
LegoJack 7 months ago
My initial thought was to add a small blower inside or file the opening larger, but the more I think about it the more I think I was just orienting it weird and under normal circumstances it would not clog unless I intentionally used cardboard soaked in oil or something
If you are having that issue, try flipping the cutter pole or exchange the nibbler for a new one, because I'm sensing a quality control issue with your unit.
jcdiamond 1 year ago
LADY DIXIE T 1 year ago
kenmiao01 1 year ago
Penolopy Bulnick 1 year ago
