Introduction: DIY Cardboard Deer Head
I have always wanted a Cardboard Deer Head like the ones you see at trendy shops or at http://www.cardboardsafari.com/shop/product_cbs1002.php but couldn't justify spending money on something I know I can make myself.
In this Instructable I will show you how I made my Cardboard Deer Head. Its not perfect but I am happy with it. The total project took me about 10+ hours off and on. My best advice is too take breaks and don't get frustrated (cutting gets a little tedious). If you had a laser cutter this would probably take you less than 30 minutes of actual work.
PLEASE NOTE
Cutting cardboard can be difficult. Please be careful to not cut yourself, always cut away from yourself!
Shall we get started?
Step 1: Supplies and Materials
The Best part about this Instructable? ITS FREE! That"s right free, that is of course if you have most of the supplies on hand.
Scissors
Box Cutter
Hot glue gun
Tape (masking tape works well)
Optional (but recommended)
Exacto-knife
Materials
Cardboard (best if it is clean, not bent up, and doesn't have anything printed on it)
Template printed off (I attached a .zip file with the template scaled so you can print at any standard printer. Also a much larger .png file if you want to scale up or play with)
Pop top
Step 2: Cut Out the Template
Start by cutting out the template. (I provided a .zip file on the last step)
Once you cut out all the pieces tape together any pieces that weren't able to be printed on one page. ( The head with the antlers and the middle) Look at the closer images for reference. If you have any questions feel free to ask
After you have taped the pieces together that needed to be, loop your masking tape on the back of the template pieces.
Step 3: Start Cutting Out the Cardboard
Once you have a piece taped down carefully start cutting out. I put sheet of cardboard down so i wouldn't cut my carpet up.
Go slow and take brakes. Use you scissors or exacto-knife for smaller more detailed cuts.
Don't worry about cutting the notches where the pieces go together just yet. I saved that for the next step to assembly line the processes.
Be sure to recycle any scrap cardboard and paper. No point in putting that in a land fill.
Step 4: Cut the Notches Out
This part in my opinion is the hardest, but dont let that discourage you.
This is where having an exacto-knife set comes in handy. Due to the varying sizes of cardboard thickness, use the printed lines more as guides vs actual. Luckily for me I had a square exacto-knife perfect for my cardboard.
Carefully cut out the notches if your cardboard is thicker than the template be sure to center your cuts. (be careful not to cut off or rip piece that shouldn't be, I did but its not a big deal)
Take the paper and tape off, and RECYCLE IT!!!
Step 5: FINISHED. Put It All Together
Finishing
Following the guide I have provided, start at the bottom and go to the top putting the pieces in the notches. Its basically biggest to smallest. When I took these photos I switched around 8 and 9 no big deal. I have since fixed it but haven't taken new pictures.
Glue the Shields together
Glue the antlers on
Glue the pop top onto the back of the shield for something to hang it with.
Finally glue the head to the shield
And done, its like your a hunter. you can now brag to your friends that you hunted and mounted your own buck.
Optional
You will notice if you used a box cutter the edges will be jagged. I sanded down the edges to smooth it out.
Other ideas
If you are like me you want something a little different. I am eventually going to spray paint mine, but you could also cover each piece in old maps (http://24.media.tumblr.com/tumblr_ku5dpjz1CS1qzn34eo1_400.jpg). You could also cover it in camouflage duck tape.
With election season coming up you could make this out of corrugated plastic political signs.
The possibilities are endless. Feel free to post other ideas on what to do.
Please post pictures of your deer head.
Final Thoughts
I had a lot of fun making this project, and would appreciate any positive feed back. Feel free to modify the template I have provided.
My hope is to make more projects like this one. Moose head, bull head, maybe even an elephant head? Who knows?
Make It Real Challenge
25 People Made This Project!
- JulienneV made it!
- Paal Aleksander AarnesK made it!
- Kingoftheokthief made it!
- RoyO16 made it!
- RoyO16 made it!
- christophes16 made it!
- AmélieC9 made it!
- AmélieC9 made it!
- AudreyE7 made it!
See 16 More
154 Comments
2 months ago
This was super helpful. I made mine using foam board and I think it turned out great.
Reply 4 weeks ago
Can you send me the file bigsissam99@aol.com
1 year ago
YO LO REDIBUJE SOBRE LAS IMAGENES A ESCALA 1: 100 Y LO MANDE A CORTAR A LÁSER PASAR SUS CORREOS PARA PESARLES EL ARCHIVO DWG
Reply 2 months ago
MI correo es frayalomxy2010@hotmail.com gracias saludos desde Cuenca Ecuador
Reply 10 months ago
jhonnyhernandeztru@gmail.com
Reply 11 months ago
e5mg137@gmail.com mil gracias
Reply 1 year ago
DI.LUZUG@GMAIL.COM
Reply 1 year ago
borisadrian75@gmail.com
de ante mano muchisimas gracias
6 years ago on Introduction
Redrawn and scaled for 3 mm plywood. Worked out great.
DXF file available if anyone wants it.
Reply 6 months ago
Late to the party, but would appreciate the .dxf files if still available...
Reply 7 months ago
plse send it to me will appreciate jonkgustav@gmail.com
thanks in advance
Reply 10 months ago
DXF-file would ne nice, thanks. Better to peter@4info.se
Reply 1 year ago
I'd like to have the file. Tried web address; it was a no-go. Thanks a bunch!
Reply 1 year ago
Hello!, can you send me the file? Thanks in advance
Reply 1 year ago
me podría enviar uno a mi también
Reply 2 years ago
Hello! Could you please share your DXF file with me? Thank you!
Reply 2 years ago
Hi Claptrap, could you please send me the DXF file if it is still being offered? Thanks.
Reply 2 years ago
Hello I think it could be funny experience trying doing it.
can you send me the file ? please
Reply 3 years ago
Would Love to get that file too!
Reply 3 years ago
En donde lo puedo descargar ??
