DIY Cheerleading Pom-Poms
234,803
34
21
Introduction: DIY Cheerleading Pom-Poms
Near the end of the school year, my six year old came home from school, just BEGGING to go to summer cheer camp. I just couldn't bring myself to pay the exorbitant fees associated with it, and so I planned my own cheer camp for her in our backyard.
No cheer camp is complete without pom-poms, however, and rather than pay $10-$15 for a set of pom-poms, I made her some pom-poms in her favorite colors for less than $1 each!
These pom-poms take less than half an hour to make (for a pair), are easy on the budget, and are GREAT for your little cheerleader!
Step 1: Materials/Tools
  • 2-3 thin plastic 54" x 108" tablecloths in different colors (2 tablecloths are sufficient if the pom-poms are a solid color)
  • Scissors
  • Ruler
  • Electrical tape
Step 2: Cut Tablecloths Into 9" X 12" Rectangles
The most efficient way I found to do this was as follows.
  • Remove tablecloth from package and unfold it partway so that it is spread out to its full LENGTH but is still folded across the WIDTH. There should be four layers of tablecloth at this point. Folded like this, the tablecloth should be about 12 inches wide.
  • Use scissors to make a cut the entire length of the tablecloth along the remaining folds so that there are four long layers 12 inches wide, stacked on top of each other.
  • Place the ruler alongside the tablecloth and cut across to the ruler every 9 inches
Step 3: Create a Stack of 25-35 Rectangles.
  • A stack of 25-35 rectangles is needed to get a full pom-pom. If using multiple colors, layering them at this point makes for a more even distribution of color in the final pom-pom. Rather than separating each individual layer, layer the sheets in their sets of four since they are already in these stacks
  • After deciding how to layer them, line them up in one even stack.
Step 4: Cut the 9 Inch Edges of Your Rectangles Into Fringe That Is 1 Inch Wide and About 4.5 Inches Long.
  • Place the ruler alongside the stack of rectangles.
  • Using scissors, cut strips about 1 inch wide and 4.5 inches long down the entire length of each of the 9 inch sides of the rectangle stack to create a fringe. There should be about 3 inches of un-cut material remaining in the center of the rectangle stack.
Step 5: Tape the Handle of the Pom-pom.
  • When all the fringe strips are cut, scrunch together the center of the pom-pom in an accordion fold.
  • Using a 4-inch strip of electrical tape, tape the center fold together tightly.
  • Add 2 to 4 more strips of electrical tape until the handle is about 3 inches wide.
Step 6: Fluff Each Side of the Pom-pom.
This step is the most time consuming part of this project. It may seem like a lot of extra work, but even if you were to buy a pre-made pom-pom for at least five times the price, they are usually sent “un-fluffed,” so you’d have to do this step anyway.
  • Working in sections, take two strips at a time and pull the two strips in opposite directions (see picture). Repeat on all the strips until the entire pom-pom is full and poofy.
  • Be careful not to pull TOO hard since the plastic is thin and will stretch and tear if the pom-pom is “fluffed” too vigorously.
The second and third pictures show how the pom-pom should look when fully fluffed.
Step 7: Get Your Cheer On!
Give your pom-poms to your pint sized cheerleaders and Go! Team! Go!
DIY Summer Camp Challenge
8 People Made This Project!
  • Make it Glow Contest
  • Make It Bridge
    Make It Bridge
  • Game Design: Student Design Challenge
21 Comments
sweetcitygirl
sweetcitygirl
Question 14 days ago on Introduction
Good morning! Great idea and so cute! You did a beautiful job! I see yr pom poms are showing 4 different colors, did you use 4 different colored tablecloths?
Thank you for yr help as I want to make these!
April
lane13
lane13
Answer 14 days ago
Yes, I used four different colors of tablecloth, but you can use just one color or as many colors as you'd like!
Milliebug267
Milliebug267
4 months ago
i used construction paper because i do not have tim to go and buy a table cloth
Milliebug267
Milliebug267
Reply 4 months ago
I meant time not tim
ariana.rodrigue
ariana.rodrigue
Question 2 years ago
do you have to use it with table cover
lane13
lane13
Answer 1 year ago
If you have some other thin plastic, it should work. I have only tried this with thin plastic party tablecloths
lane13
lane13
Reply 1 year ago
In Step 4, it tells which side of the pieces to cut and how much.
I'm sorry yours didn't turn out how you were hoping!
FrancescaC31
FrancescaC31
Question 4 years ago on Step 7
Is it 2 table cloths per Pom Pom or per pair?
McKennaM5
McKennaM5
Answer 2 years ago
Per pair
lane13
lane13
Answer 4 years ago
2 tablecloths for a pair!
kylie.janouskovec
kylie.janouskovec
5 years ago
Unfortunately this tutorial did not turn out correctly or look at all like a cheer pom-pom for me. If you do end up trying this DIY out, best of luck!
29maycock
29maycock
Reply 2 years ago
That is sad I bet u worked very hard
tjrthe3rd
tjrthe3rd
Reply 3 years ago
I think you may have over looked the last step
RobinC60
RobinC60
Reply 4 years ago
Looks like you may have accidentally skipped the tedious but necessary fluffing step. Step 6.
29maycock
29maycock
2 years ago
That looks really cool 😎 I am I
29maycock
29maycock
Reply 2 years ago
I meant that looks really cool
tjrthe3rd
tjrthe3rd
3 years ago
This worked out great for us! We did a double twist on some, 1 on others then some just got a simple tug like the others did after the twist. Thank you Lane 13!
ClaraJLees
ClaraJLees
3 years ago
I used 60 rectangles for each instead of 25 and it took me almost 2 hours per side of the pin poms
