// boolean to know if the balance has been set boolean balanceSet = false;
//place holders for colour detected
int red = 0;
int green = 0;
int blue = 0;
//floats to hold colour arrays float
colourArray[] = {0,0,0};
float whiteArray[] = {0,0,0};
float blackArray[] = {0,0,0};
//place holder for average int avgRead;
void setup(){ //setup the outputs for the colour sensor
pinMode(2,OUTPUT);
pinMode(3,OUTPUT);
pinMode(4,OUTPUT); //begin serial communication
Serial.begin(9600); }
void loop(){
checkBalance();
checkColour();
printColour(); }
void checkBalance(){ //check if the balance has been set, if not, set it
if(balanceSet == false){ setBalance(); } }
void setBalance(){ //set white balance
delay(5000); //delay for five seconds, this gives us time to get a white sample in front of our sensor
//scan the white sample.
//go through each light, get a reading, set the base reading for each colour red, green, and blue to the white array
for(int i = 0;i<=2;i++){
digitalWrite(ledArray[i],HIGH);
delay(100);
getReading(5); //number is the number of scans to take for average, this whole function is redundant, one reading works just as well.
whiteArray[i] = avgRead;
digitalWrite(ledArray[i],LOW);
delay(100); } //done scanning white, now it will pulse blue to tell you that it is time for the black (or grey) sample.
//set black balance delay(5000);
//wait for five seconds so we can position our black sample
//go ahead and scan, sets the colour values for red, green, and blue when exposed to black
delay(100); getReading(5);
blackArray[i] = avgRead;
//blackArray[i] = analogRead(2);
delay(100); } //set boolean value so we know that balance is set
balanceSet = true; //delay another 5 seconds to allow the human to catch up to what is going on
delay(5000); }
void checkColour(){
digitalWrite(ledArray[i],HIGH); //turn or the LED, red, green or blue depending which iteration
delay(100); //delay to allow CdS to stabalize, they are slow
getReading(5); //take a reading however many times
colourArray[i] = avgRead; //set the current colour in the array to the average reading float
greyDiff = whiteArray[i] - blackArray[i]; //the highest possible return minus the lowest returns the area for values in between
colourArray[i] = (colourArray[i] - blackArray[i])/(greyDiff)*255; //the reading returned minus the lowest value divided by the possible range multiplied by 255 will give us a value roughly between 0-255 representing the value for the current reflectivity(for the colour it is exposed to) of what is being scanned
digitalWrite(ledArray[i],LOW); //turn off the current
LED delay(100); } }
void getReading(int times){
int reading; int tally=0; //take the reading however many times was requested and add them up
for(int i = 0;i < times;i++){
reading = analogRead(0);
tally = reading + tally;
delay(10); } //calculate the average and set it
avgRead = (tally)/times; }
//prints the colour in the colour array, in the next step, we will send this to processing to see how good the sensor works.
Great, but your explanation is not entirely correct as LDR's dont distinguish in wavelength. What is basically happening with these sensors is that when e.g. pointed at a red object there will be hardly any reflection of the green and blue and the LDR sees that as 'less light'
I think this is cool, although I can't see the video from my tablet. I think it's my tablet and not your video, though. XD
X
Autodesk Instructables
Your privacy is important to us, so please take a moment to indicate if we may collect and use your data.
We want you to have a good experience with us. To do this, we collect data about your online behavior or attributes and use advanced data analysis so that we may deliver new versions of our sites with customized content.
6 Comments
OngE2 7 years ago
helo sir, i want to ask why my result is negative value when i near to red object with my sensor?
kartik00013 7 years ago
GerardoM21 8 years ago
// Define colour sensor LED pins
int ledArray[] = {2,3,4};
int red = 0;
int green = 0;
int blue = 0;
pinMode(2,OUTPUT);
pinMode(3,OUTPUT);
void loop(){
checkBalance();
checkColour();
printColour(); }
delay(100);
delay(5000); }
void checkColour(){
LED delay(100); } }
void printColour(){
Serial.print("R = ");
Serial.println(int(colourArray[0]));
Serial.print("G = ");
Serial.println(int(colourArray[1]));
Serial.print("B = ");
Serial.println(int(colourArray[2]));
delay(2000); }
ankur sharma 8 years ago
diy_bloke 8 years ago
gearup500 8 years ago
