Introduction: DIY Denim Bucket Hat & Shorts Set From Old Jeans (Beginners Sewing)
If you have an old pair of jeans or come across a cheap pair at the thrift store then here's a fun way to transform them into a cute denim shorts and bucket hat matching set with some simple sewing!
Full video tutorial: https://www.youtube.com/watch?v=8qCivqvdH1E
Step 1: Gather Materials
What you'll need:
- Pair of jeans
- Sewing machine: https://amzn.to/2HZ779o
- Fabric scissors: https://amzn.to/399tOlJ
- Pins and magnetic holder: https://amzn.to/2Yu2XMy
- Seam ripper
- Pencil
- Bucket hat sewing pattern https://www.etsy.com/listing/744796615/trend-bucke...
*Miaira is a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for sites to earn advertising fees by advertising and linking to Amazon.com.
Step 2: Mark & Cut Shorts
While wearing the jeans, use your pencil to mark a spot where you'd like the shorts to fall. Then use fabric scissors to cut horizontally across each pant leg at that marked spot, cutting slightly diagonal lines with the outsides being a bit higher.
Step 3: Trace Pattern & Cut Pieces
Place each pattern piece (top, crown and brim) onto the excess pant leg material. Trace them with a pencil and cut them out. Note that for the crown and brim, you'll need to line one edge up with a folded side of the denim. The pattern instructions explain in further detail, if needed.
Step 4: Sew & Notch Crown
Sew the edges of the crown together to connect the ends. Then notch the shorter side of the crown with your fabric scissors. This will allow the material to attach to the top of the hat more easily. This is the inside of the hat, so the notches will not be visible.
Step 5: Sew Top, Crown and Brim Together
Align the notched edges of the crown with the edges of the round top piece, then sew them together all the way around. After that, line the bottom of the crown up with the brim and sew all the way around to attach those pieces. Flip the hat inside out to the correct side.
Note: Many people use a double layer for the brim but I decided to use just one layer since the denim is already pretty thick.
Step 6: All Done!
Voila! You've transformed a pair of jeans into a cute, nostalgic denim set that's perfect for warm weather. Thanks for checking out this tutorial!
Instagram: https://www.instagram.com/miairajennings/
YouTube: https://www.youtube.com/miairajenningstv
Website: http://miairajennings.com
Pinterest: https://www.pinterest.com/miairajennings/
Business Inquiries: MGJmedia@gmail.com
Shop my Amazon store: https://www.amazon.com/shop/miairajenningstv
Blog: https://livegrowglow.com
