Introduction: DIY Dice in Tinkercad
today we will make this dice in tinkercad
Step 1: Add Cube
Add one cube form your panel and place it middle of your workspace
Step 2: Change Radius
change the radius form its property panel change it to 3
Step 3: Add a Number and Make It Stand
add a number form text and charater in panel list view then select a number and rotate it vertical 90 degree to make it stand and make it a hole from the property
Step 4: Group and Aline Them
first left click drag them both then select then there will be option to make to Aline then select the cube you will see few dots then click then click first dot that can make them go on the surface of the cube then other click middle so it can make it go in center of the side ou can see it on next step's image
Step 5: Make a Group Again
so select both of the number and cube make a group you will see a hole
Step 6: Last Step : Do Same
do the same thing with other numbers
