DIY Drawerslide CNC Machine - Gantry Re-design
Intro: DIY Drawerslide CNC Machine - Gantry Re-design
I built a CNC machine that used a small inexpensive rotary tool that rode on one drawerslide. It was fun to see it actually work (this was the first CNC machine that I have ever built) but it was limited in its ability to cut larger pieces of wood. The small rotary tool also lacked torque and had a tendency to wobble due to no bearing at the collet.
So I redesigned the gantry to hold a router that could use standard sized 1/4" bits.
Here's a quick little video using Mach3, LazyCam, and some cheap stained pine.
10 Comments
ankitvaid1990 8 years ago
Hello @stangtime i like your CNC machine design and i want to make it. Would you like to share the diagram of your machine wooden parts so i can cut them with proper dimensions.
mmcgregor4 10 years ago
stangtime 10 years ago
stangtime 11 years ago
Electronics Man 11 years ago
pfred2 11 years ago
https://www.youtube.com/watch?v=fHPKaHLzXes
That drives a nested square tube up and down. I don't use any drawer slides. My nested square tubes look like this:
http://i.imgur.com/PHZCW.jpg
I have six inches of Z axis travel.
For that fuzz you're getting in your cut burn it off with a torch. Burning the letters makes them stand out nicely too. It takes a touch to burn it right though. I've routed a lot of signs. Oh use a V groove bit too. Square is a bit much. Sanding is too tedious.
Somethingtotallyrandom 11 years ago
sleeping 11 years ago
