Introduction: DIY Duct Tape Flower Pen
Have you ever been in need of a pen, pencil, or marker that has style but is also easy and cheap to make? Well, I have a solution! You can make a DIY Duct Tape Flower Pen! Making one of these is very easy, fast, and cheap. The resources you will need include:
- Duct Tape
- A Writing Utensil(pen, pencil, marker, etc.)
- Scissors or Exacto Knife
- Cutting Board(if using an Exacto knife)
- Ruler
Here are the steps to making this DIY
Step 1: Getting Prepared
Put down your cutting board on a hard surface and choose any design or color of duct tape you want. Then place 12 inches of the duct tape on the cutting board or cut 12 inches of duct tape with your scissors.
Step 2: Cutting the Tape the Right Petal Length
Cut the strip of duct tape into 1 1/2 inch intervals. (Note: You'll need several 12-inch strips depending on how big you want your flower)
Step 3: Part 1: Transforming Your Tape Into Petals
Fold your 1 1/2 inch piece of tape from the corner to a little left of the center on the duct tape piece like so.
Step 4: Part 2: Transforming Your Tape Into Petals
Then, fold the sticky corner of your duct tape to the non-sticky corner on the other side like this.
Step 5: Part 1: Adding the Petals to Your Flower
Now, we are going to add the petals to our flower. To do so, you put the sticky part of your petal on the bottom of your writing utensil, then wrap the sides around it.
Step 6: Part 2: Adding the Petals to Your Flower
Then you grab another one of your folded petals and place it right across from the other petal on the base of your writing utensil. Wrap it around and you get two petals.
Step 7: Part 3: Adding the Petals to Your Flower
Then do the same and wrap the other petals around the opened sides of your flower. Keep repeating those steps until you have just the right size duct tape flower pen.
Step 8: You Did It!
You've done it! Great job! I hope this tutorial helped you out:)
