Introduction: DIY Easy Accessories Pouch
It can be difficult to try and store small things, and then lose them because they are spread out all over. With this easy to make pouch, it will be easier to keep smaller things in control. Follow this guide to learn how to make one yourself!
*- This craft is found on the channel "Toni art and craft" on YouTube.-*
Two Sticky Notes/Rectangular Strip of Paper
Glue
(Optional) Art Supplies
Step 1: Assembling the Shape
*If you are using a rectangular strip of paper, then go on to the next step*
Stick the sticky part of one stick note onto the other.
Step 2: Decorating
Draw/Color on the rectangle, but be careful not to make it too wide! Draw around the center. After this step you will not need your art supplies.
Step 3: More Assembling
Flip over the paper and apply glue in an 'L' shape with the left and bottom corners, as shown in the picture.
Step 4: Almost Finished!
Take the right side of your rectangle and stick it to the glue on the left side.
Now you should have a cylinder type of shape.
Next, push the part of the cylinder parallel to the glue on top the glue. This is a little tricky, but with the pictures, it should be manageable.
Step 5: Done!
If you want to, store something inside the pouch and seal the top shut with glue or tape or anything else that you can use. The pouch says 'Strawberries!' on it but I'm putting a banana eraser inside! :D
