Introduction: DIY Floral Hair Clip Accessories
This is a guide for making really easy and quick hair accessories. You can also make them with a lot of other things, not just flowers. I had these lying around, so I used them.
Materials:
- glue
- hot glue gun
- fake flowers
- hair clips/ties/band
- scissors
- disposable plate
- tiny paintbrush (cheap-o)
- newspaper
Let's get started!
Materials:
- glue
- hot glue gun
- fake flowers
- scissors
- disposable plate
- newspaper
Let's get started!
Step 1: Prep the Flowers
For this step, all you need to do is pick apart the flowers. It's pretty simple!
Pull off the bracket thing holding the leaves on and take off the leaves. Cut off the stem and separate the bits.
Step 2: Glue & Finish
Take some hot glue and put it on the clip and stick the flower onto it. It helps to leave a bit of the white part in the photograph to make an 'anchor' in the hot glue.
Let dry.
Wear.
That's it!
This is so easy I was able to watch TV while I was doing it, but it's still so cute! Good luck :)
Let dry.
Wear.
That's it!
