DIY Garden Gate
Intro: DIY Garden Gate
This is a tutorial on how I made two Garden Gates using Wood and Steel angle iron.
STEP 1: Materials Needed
Duration : +- 4 Hours
Materials Needed:
10 x 3000mm x 114mm ( 10 ft x 0.375 ft ) Pine planks
12 m ( 40 ft ) angle iron
60 Self drilling screws
2 Hinges
1 Gate Lock
Tools needed:
Circular Saw
Drill
Combination Square
STEP 2: Cutting
Mark your wood where you want to cut it. I used the frame as a guide as it wasn't an exact length.
STEP 3: Fitting
Fit the planks you just cut into the frame and start screwing them to the frame with the tek screws
STEP 4: Hinges
Mark area where hinges will be and screw hinges into place
STEP 5: Lock
Choose where you want to put the lock adn mark the holes.
Drill holes for the lock and fasten it with the bolts that came with the lock
STEP 6: That's It!
The gate is done. Now just hang it and you have made a Rustic looking garden gate in under 4 hours.
6 Comments
DIY Hacks and How Tos 6 years ago
This looks really nice. Did you weld the angle frame together?
jpvanstaden91 6 years ago
Yes, Unfortunately I only came across Instructables after I made the frame. That is why it isn't included in the process.
Swansong 6 years ago
That looks really nice :)
Thanks a lot! You're Great!
rayp1511 6 years ago
The rustic steel and wood look goes well with the brick, nice work.
Thank you! Was my first time showing anyting I've made
