Introduction: DIY Glitter and Marble Paint Ornaments
Today I will be making a DIY glitter ornament along with a DIY marble paint ornament to dazzle up my Christmas tree. I hope these will make your Christmas tree super fun with these awesome DIY's. I got these amazing ideas from heyheyheatherk.com (glitter ornament) and happyhooligans.ca (marble paint ornament).
Step 1: Materials
For this DIY you will need:
-Glitter
-Mod podge
-Water
-Clear ornaments
-Small bowl or container
You could also use floor wax instead of mod podge and water.
Step 2:
Put some mod podge and a tiny bit of water in your small bowl/container.
Step 3:
Remove the top from the ornament then pour your mixture into your ornament and swirl it around until the inside is coated.
Step 4:
Drain the excess mixture from the ornament into your small bowl/container.
Step 5:
Pour your glitter (generous amount) into the ornament and swirl it around till the inside is covered.
Step 6:
Drain the excess glitter into a small bowl or wherever you got it from then put the top back on and you are done.
Step 7:
Put on your tree and enjoy!
Step 8: DIY Marble Paint Ornament
Step 9: Materials
- Acrylic paint
-Clear ornaments
Step 10:
Remove the top of the ornament, then grab one of your paint colors.
Step 11:
Squirt some of your paint into the ornament. Then give the ornament a quarter turn and squirt again.
Step 12:
Repeat a few more times while tipping and turning your ornament so the paint coats the inside of the ornament. Remember to leave space for the other colors.
Step 13:
Repeat with the rest of your colors. If any space is uncovered, turn the ornament to splash some paint to cover the space.
Step 14:
Once the ornament is completely covered, turn it upside-down and drain the excess paint into your small bowl/ container. This might take a while so you may need to leave it over night. The pattern the drained paint makes is so cool!
Step 15:
Once your ornaments are dry, put the top back on then hang on your tree and enjoy!
