DIY Hammock Stand
Intro: DIY Hammock Stand
We recently bought a portable hammock and we've enjoyed so much on our hiking and camping trips that I decided I wanted to hang it at home to enjoy on our backyard. I looked at the available hammock stands and they seemed quite expensive but very simple so I decided to give it a try. I based the design on some of the available commercial options. This is what I used:
2 - 8' 2X4 beams
2 - 6' 2X4 beams
2 - 4' 2X4 beams
8 - 5 and a half inch 3/8" bolts
4 - 6" 3/8" bolts
24 - 3/8" washers
12 - 3/8" tightening washers
2 - 8' 2X4 beams
2 - 6' 2X4 beams
2 - 4' 2X4 beams
4 - 6" 3/8" bolts
24 - 3/8" washers
STEP 1: Angled Cuts.
The first step is to make the angled cuts of the beams that will hold the hammock, the 6' beams. I made a 30 degree cut so that the angle to the floor would be 60 degrees.
STEP 2: Drill the Holes
There are quite a few holes to drill for the bolts. The most tricky ones are the ones to attach the angled beams to the base.
The angled beams will be "sandwiched" between the two 8' beams and the bolts will go through all three pieces. To make sure I had a straight hole for the bolt to go through all three I laid down all three four pieces on the floor just as they would when standing and drilled once through all the wood. As you can see in the picture I made the holes 1" from the edges.
I should also note that the angled beams are not flush with the base beams. This is because the base will rest on top of the 4" pieces and hence be elevated about 2" from the floor. Having the angled beams reach all the way to the floor adds stability. You could also cut a "bed" in the base beams to fit the two 4" pieces so that the base would rest on the floor.
The other holes to be drilled are holes for they eyebolts where the hammock will hang, and the holes to secure the base to the "feet" the two 4" beams.
STEP 3: Assembly
The final step is to bolt everything together. I used a washer on each side the bolt and a tightening washer on the nut side.
After using it a few days I've thought of a couple of improvements. The angled beams flex quite a bit when the hammock is rocking so I think some tensioners running from the top of the beams to the edge of the feet would increase the stability. however they could become tripping hazards!
I should also note that I choose these dimensions based on my hammock's length.
So far it's held pretty well up to 200 pds.
75 Comments
kaway27 13 years ago
gdsmit1 7 years ago
That's a great looking stand.
JeremyO20 8 years ago
kaway27 8 years ago
kaway27 8 years ago
I just tried to download the file myself and it opened fine. Try update or reinstall your Adobe Acrobat.
TIPOC 8 years ago
kaway27 8 years ago
TAYETURANA2 8 years ago
kmedina58 12 years ago
kaway27 12 years ago
TheDownsProject 11 years ago
Joseph.of.Jesus 8 years ago
You could find the angles, though with a bit of work, by finding the ridge length of your hammock, and the geometry to the hanging angle (30 degrees) and the height. There's an online calculator for hanging a hammock. Try that, it should make it easier.
kaway27 11 years ago
CarsonG1 8 years ago
i was looking at your design and decided to would look better with my backyard
i saw your drawing attatchment and appreciate it but what size bolts did you use
if you even remember of course
thanks
Cyrus KaelA 7 years ago
I'm not good with measurements. Can you give me something for scale of the size?
kaway27 how did you anchor your 4x4 uprights to bottom 2x4?
DrewE1 8 years ago
cmcclendon65 9 years ago
Just a constructive piece of info.Weight (mass) is measured in pounds (lbs). It might scare people who are considering trusting your design if you are using inaccurate units.
dhendriks 9 years ago
Weight and mass are two different units of measurement. Mass is measured in grams. It might scare people who are considering trusting your comment if you are using inaccurate units.
