Introduction: DIY Industrial Black Pipe Lamp With Touch Switch
In this instructable you can see how to make industrial pipe lamp. You can change the design and make your own or you can replicate the one I made. The lamp is made with black pipe and edison bulb for cool industial look. The project can be built with minimal tools.
Step 1: Materials
Black pipe and fittings
Bulb Socket
Edison Bulb
Electric Wires
Superglue
Black matte paint
220v Touch Switch
Copper wire
Few years ago I made a black pipe hanger for a DIY contest
Few days ago I decided to make a lamp that will look like it
I also used black pipe to build the lamp
You can easy change the design and make your own.
It is a fast and easy to build project and minimal tools are needed
Step 2: Production
I used rubber coating wire for more safety
I wrapped the ground wire around the bulb socket to make contact with the lamp body
Try not to turn the wire with the pipe parts when connecting them
Make a hole under the lamp for the electric wires
I added a touch on/off switch from aliexpress on the wire, the touch switch has 4 wires, one connected to the lamp metal body.
