Introduction: DIY LENS HOOD Box-Shaped [ Square ]
Hi all,
This is my first DIY, a box-shaped lens hood for the camcorder.
with simple tools and materials around you, you can create a lens hood with the same functionality without spending much money. set aside time for this.
TOOLS :
- Paper cutter
- scissors
- a ruler
- markers
MATERIAL :
- cardboard
- Adhesive (super glue)
- (Spray paint - black DOV)
TOOLS :
- Paper cutter
- scissors
- a ruler
- markers
MATERIAL :
- cardboard
Step 1:
step I
FIN
create a line that forms the basis of the fin. would be easier if you create a basic form and make reference to the four fins are. Do not forget to add the distance in each of the fins on each side. this is to ensure that the form in order to remain robust.
HOLDERS
make the outer diameter of the circle according to your camera lens circle followed by a larger diameter (about 10mm larger). you may need two forms of the same for this section.
ARM
create a rectangular outline for the four arms measuring 30mm x 35mm (adjustable). The fourth arm serves as a sleeve between the fins and the holder.
step II
cut "cardboard" with follow the path you created earlier. then shape into a square of cardboard. Dab glue enough on the two arms meeting.
step III
raft every piece suit each function.
FIN
HOLDERS
ARM
step II
step III
Step 2:
step IV
give the final touch "DOV" using spray paint. you can sand the board in advance of each field for more refined results.
* Some images of DIY lens hood square along with other equipment attached to the Canon HF10 mine.
so-and-so much, Happy DIY !
