Introduction: DIY Little Bits Speaker
With this, you can play your favourite music from wherever you are with a wifi connection.
Step 1: Laser Cutting
With these attached PDF's, send these to your laser cutter, and wait for them to be cut out. When that is done put them together and wrap the edges with duct tape (the duct tape is not needed, it will just make the speaker look better)
If you're building this with wood, use wood glue, if you're not using wood, I would still recommend using wood glue
Step 2: Circuitry
With this little bits (insert little bits) follow this diagram for the circuitry. If you want, you can put a split where the speaker goes, and put two speakers for whatever you're playing to be louder.
Step 3: Fitting It All in the Box
This step is pretty straight forward, just put everything inside the box.
Step 4: Connect the Cloud Bit to Your Computer
You first need to go to the cloud bit website and create a new account. After creating a new account make sure that the light of the cloud bit is green and is connected.
Step 5: Enjoy
Once connected to the cloud bit, you can start jamming out to your favorite songs
