DIY Modern Tripod Floor Lamp
Intro: DIY Modern Tripod Floor Lamp
Have you ever seen those designer tripod lamps that are ridiculously expensive, well this week we build one a lot cheaper using a paint bucket and LEDs!
STEP 1: Materials
For this project I used:
- A couple of 1x2s
- A small section of 2x4
- Paint Bucket
- Steel Bar
- LED Strip: https://amzn.to/2Glp7bJ
- 12V Power Adapter: https://amzn.to/2DidEci
STEP 2: Mark and Cut
The first step in this project was measuring out my legs and then cutting them to size.
STEP 3: Shape the Ends
Then using my disk sander I rounded over the ends of the legs to make to break up having so many straight edges.
STEP 4: Mark the Holes
Next, I marked the locations for the legs.
STEP 5: Drill the Holes
After marking ou the holes I went ahead and drilled them with a 1/4" drill bit for the 1/4" bolts.
STEP 6: Making the Center Piece
I traced an equilateral triangle of the right size on a 2x4 and then cut it out on the bandsaw.
STEP 7: Leg Assembly
STEP 8: Drill More Holes
Then I drilled some more holes to be able to mount up the legs.
STEP 9: Make the Lamp
The actual lamp portion of the project I made using a paint bucket that is available at Home Depot. Then I used an LED strip to line the inside of the bucket.
STEP 10: Install the Power Jack
The next step was to install the power jack, so I went ahead and drilled a hole, soldered it up and that was done.
STEP 11: Install Mounting Bolts and Diffuse the LEDs
I clipped off the handle and enlarged the pre-existing holes and installed the 1/4" mounting bolts. To diffuse the LEDs I just used a bit of parchment paper cut to size.
STEP 12: Mark, Cut, Bend
Next up I needed to make a bracket to hold up the lamp portion. To do that I just cut a metal bar to size, marked it, and then scored along those lines with the angle grinder to make it easier to bend it. Then I bent it to the proper shape. Really, you could do whatever you think looks good for this step.
STEP 13: Drill Some More Holes
To drill some holes in the bracket, I used a self-centering automatic punch to mark the locations and then drilled some more 1/4" holes.
STEP 14: Paint
The only paint I used in this project was to give this bracket a light coat of black.
STEP 15: Final Assembly
Then it was time for final assembly, I just drilled a hole into the centerpiece for the bracket to bolt into and then finished butting it all together.
STEP 16: It's Done!
That's it, now enjoy the super cool lamp you made with a paint bucket.
8 Comments
Penolopy Bulnick 5 years ago
paolochiarlone 5 years ago
One comment: I believe that painting the interior in white would give you a little more bounce hence more reflected light, what do you think?
Make And Repeat 5 years ago
YaƫnD 5 years ago
jtreadgold 5 years ago
GTO3x2 5 years ago
