DIY Organic Vertical Planter
Intro: DIY Organic Vertical Planter
Ever wanted to grow plants but you didn't have enough room for them? Have you ever wanted to grow plants in a more water-friendly way? Are you tired of raking and your garden and pulling out those stubborn leaves or using harmful chemicals that are not healthy for you and damage the fruit's flavor and texture?
The simple answer is a vertical planter: The vertical planter allows you to grow plants in a very small area limited only by height, and that too can be amended. It uses a water-friendly watering system where the water is not wasted but moves on to other plants. It needs no chemicals for those pesty weeds! Did I mention it is easy to make?
Materials:
- Any length 4-6 inch wide PVC or any other kind of pipe
- Planting soil and compost
- Any plants you want (I don't recommend large plants or bushes)
- Large pebbles of about the same size to put under
- A drip irrigation pipeline (you can also water from above and it will trickle down)
Tools:
- Circular drill bit (Or a jigsaw if you don't happen to have one)
- Drill
Materials:
Tools:
- Drill
STEP 1: Choosing Your Pipe
The first step is deciding the height and width of the pipe. The difference between the width of the pipes depend on how much space you have and and the space you want between the plants- for a 4 inch pipe I recommend only one hole so the plants have enough room for their roots and to expand hole only on one side of the pipe on each row (or if you are planting flowers you can make 2 holes on each side). For 6 inch pipes you can have up to 3 holes in each row depending on which plants you choose (I recommend three holes for flowers only, the rest either one hole or two). The size of the hole directly depends on the plants type and size. I made a 2.35 inch wide by 2.8 inch high hole ( 6cm wide by 7cm height hole)
You can cut the pipe to any length you want, depending on your restrictions. The pipe must be put at least a fourth of its height above ground, in the ground.
I mean by this that if you want the height of your pipe to be 4 foot above ground, you will need to have a foot below ground, which means that the total height of the pipe is 5 feet.
Another example for this is, if you want the height above ground to be 2 meters tall then you will need 50cm underground, thus having a two and a half meter pipe.
STEP 2: Cutting Out the Holes
**Safety first, always remember, wear safety glasses and gloves!**
Measure the height of the pipe and mark a line that shows where the pipe goes under the ground we discussed this in the earlier steps. . Divide the pipe circumference into 4 equal parts. You need to choose whether you want to grow herbs, fruits and vegetables or flowers. For vegetables you will need to mark every 11.8 -15.7 inches (30-40cm), for flowers (depending on their size) should be about 7.9-11.8 inches (20-30cm). . Whichever one you choose, keep the marks at a constant length. A good trick to make the marks constant and aligned, stretch out a piece of twine from one side of the pipe to the other (make sure it is perpendicular to the top and bottom!), and mark each hole from the ground level line you made earlier.
There are several ways to cut out the holes, depending on your tools:
- If you are using a circular drill bit, simply place the drill at the middle of your marking and drill through.
- If you are using a jigsaw
* First make a rectangle out of paper or cardboard according to the size of the hole you want.
* Mark the middle of the cut-out's width and place it on top of the mark on the pipe, parallel to the ground.
* Outline the cut-out onto the pipe.
* At each corner of the rectangle, drill a hole the size of the jigsaw blade you are using.
* Cut according to the holes and outline you made.
STEP 3: Digging the Hole
Dig a hole a little bit wider than the width of your pipe and at the depth of the line in which the pipe goes to the ground (The one you marked in step 2). Now place the pipe in the ground and insert (through the top or any of the holes) the pebbles until ground level. If the ground is soft where you are digging, place heavy rocks underground (so they won't be seen) around the pipe as to keep it from tipping over.
STEP 4: Watering System
There are 2 major ways of watering the vertical planter.
- One, as I used, is to insert a drip irrigation pipeline (as shown in photo) from the top or the bottom (depending on your needs) into the pipe.
- The second way, if you have sparse soil, simply water from the top part and let it trickle down to the bottom.
STEP 5: Filling the Pipe and Planting Plants Inside.
Put the planting soil until you reach the bottom of the first hole. Spread a small bit of compost at that point (be careful, as too much compost will burn the roots). Insert the first plant through the hole and cover it with the potting soil, until you reach the next hole. Repeat as needed. Keep in mind that each plant has its unique structure- plants like cucumbers and strawberries tend to snake down, so plant them near the bottom so they wont choke the other plants.
STEP 6: Tips
- Make sure the planter gets sun from all four sides, or at least as much as possible
- Strawberries are good plants to plant inside
- Try using all-year round plants to keep your planter pretty all year
For people living in apartments, keep the planter steady by putting it in a bucket or anything else heavy enough to keep it from tipping over and falling (also you can make it a base or stand).
This is my first Instructable so don't be harsh :)
Comments and improvements are always welcomed.
STEP 7: After a Month or Two :)
So guys we took some pictures of the Planter today so you could see what happened to it. Enjoy :)
103 Comments
PrajjwalP 4 years ago
panicmose 4 years ago
Bspoony 7 years ago
OK To try and add some actual reality check to the comments I read i post the following. And yes, I would build this.
Plasticised PVC has been used for over 50 years without a single known case of it having caused any ill-health and the environmental effects of phthalates are known to be minimal. Academia and industry have continually worked together to address the concerns and conduct necessary research, making phthalates some of the most researched and best understood chemicals today.
Carcinogenicity
Some concerns have been expressed concerning carcinogenicity. In 1980s, liver tumour of rats and mice was reported upon an extremely high dosing of DEHP, but subsequent studies clarified that such effects are unique to rodents such as rats and mice and would not occur in primates such as monkeys. In 2000, the International Agency for Research on Cancer (IARC: an affiliate organisation of World Health Organisation - WHO) re-classified DEHP from Group 2B to Group 3 in their carcinogenicity evaluation, thus clearly showing that DEHP is not carcinogenic to humans. Tea and tap water (drinking water sterilised with chlorine) are also included in Group 3, which means that the carcinogenicity of DEHP is lower than that of coffee.
Endocrine Modulation
In past years concerns have been reported on about possible risks of PVC products related to endocrine modulation and alleged disruption of certain phthalates.
Phthalates are a large and diverse family of chemical substances with different hazard classifications regarding human health.
Further information and references may be found at
http://www.plasticisers.org/en_GB/health/health-misconceptions
JorgeG52 7 years ago
Como resolvo o problema do substrato escorrer pelos furos?
avinsen 12 years ago
As for plumbing, PVC is used for water/waste leaving the house, not coming into it.
The reason PVC is not food safe is because petro chemicals leech out of it over time. This means that over time, what ever is stored inside absorbs those chemicals. If it is food, and the food is ingested, then those chemicals gets inside whoever eats that food.
This is a great idea, but we need a different material to build it from.
Jorge Maeda 8 years ago
Que tal bambo?
crispyjones 12 years ago
Further, food manufacturers (and I do work for one) will not use PVC for their packaging because of the leeching concern. This leeching is what makes PVC not food grade.
Now, I'm not saying that your project is bad. But I am concerned about the material used. Especially since I assume this is something that will be out in the full sun, where it will get heated up.
The vertical watering system is a great idea and I hope to use it myself.
But I couldn't just let everyone thing that is was perfectly okay to us PVC in food manufacturing, even when it's growing it yourself.
elizabethingham1 10 years ago
So, what you're really saying is this project is great for plants that aren't going to be there for long periods of time. Pvc's chemicals take quite a while to leech into anything that is put in it. That's why it's neither safe nor unsafe. Am I correct?
avinsen 10 years ago
Not quite. The idea is great, but the material is questionable.
While some will scoff at the left leaning liberal organizations who issue warnings on these and other materials, it is worth noting that the FDA has yet to allow rigid PVC to be used in food packaging. Also, I mentioned environment as an issue. In particular, I was thinking of the heating the material will get from the sun. It speeds up the transfer of chemicals from the plastic to the soil it will be containing. Of particular concern is vinyl chloride monomer (VCM) which is used to create PVC and is a known carcinogen.
If you do a search on the internet, you'll see plenty of arguments for both sides of the debate. In the end, the choice is yours. But for me, I'd steer clear of the PVC in this project. Remember, x-rays were once thought to be completely harmless. Now you can't get a medical tech to be in the same room with the x-ray machine when it is being used.
mikeguen 9 years ago
avinsensilkier
I
am interested in this project. I know that I can use Clorox in a water
solution to clean wine and beer bottles to use again for home brewing. Could a
Clorox solution wash be used to reduce the hazard in a PVC pipe, to warrant use as a
growing structure? If not I am going to use ceramic drain tile to accomplish
this project.
silkier 9 years ago
One minute you talk of PVC the next you are talking about phthalates, not the same thing at all. Please make your mind up and take a look at some peer reviewed research on the subject of PVC in contact with growing plants.
avinsen 9 years ago
The reason for the mention of phthalates is because of it's use in plastic manufacturing. It is used as a plasticizer and is what gives plastics its ability to flex and bend without breaking. Otherwise, plastics are very rigid and fragile. You can see an example of this when you see old plastic that's been out in the sun for extended period. As the phthalates leave the plastic, it become brittle and inflexible. This is due to the fact that the phthalates have left the plastic leaving it in this fragile state. Plastics and phthalates are both part of the same conversation. In this context, it is difficult to separate the two.
That said, if you have examples of peer review articles in a scientific or trade journal, please feel free to post it, as I would love to read it.
Thanks.
If this use of PVC worries you than you have a great deal to worry about. If your house or apartment is plumbed with PVC than you are putting PVC water on your food, your house plants, drinking it, and cooking with it. If your garden hose is made of PVC, than you are watering your garden with PVC water. Hell, your gutters could be made of PVC, than all the rain washing off your roof onto your yard is PVC water.
jusdafaks 11 years ago
Como evitar que a terra (substrato) escorra pelos furos ao longo do PVC?
Topsail Time 8 years ago
Very cool! Thanks for posting.
Maria Knows 8 years ago
Hey, great concept, really liked your choice of plants too. Keep innovating.
Cheers!
motogazi 9 years ago
After all this talk about PVCs (even though I'm late on the issue) and pointing to green peace, etc... I thought I'd look up on more of an authoritative location. Please read at your leisure and make your own decisions.
http://toxtown.nlm.nih.gov/text_version/chemicals.php?id=84
(US Nat'l Library of Medicine talking about PVC and health concerns.)
