DIY PVC Pipe Bicycle Trailer (Single Wheel)
11,777
145
9
Introduction: DIY PVC Pipe Bicycle Trailer (Single Wheel)
About: US Army Retired (medical) - Always Looking for handy work to do. Wood & PVC projects. Getting ready to make a 95% PVC pipe uni-bycycle-trailer to haul my best friend, (ALO - My Service Dog), around in... …
Sorry guys! In hindsight, I wish I had taken the measurements on this trailer as I was building. This is my first attempt at making a bicycle trailer.
I saw a lot of different "single wheel" trailers and wanted to build something strictly out of PVC pipe and plastic.
I had the plans in my mind so this whole project was touch and go as far as measurements.
The overall measurements are about 5 feet 7 inches long and 14 inches high at the front. From the base of the wheel to the top of the fender frame it's about 25 inches tall.
Step 1: PVC Bending Jig...
I used a Heat Gun to heat the PVC pipe for the curves I needed. I made a jig to do this. I used screws and plywood. Wear gloves when holding it it place to cool!
This part takes a little patience as you don't want to burn (yellow) the pipe.
Step 2:
The piece that the wheel attaches to, I heated the pipe and pressed a 1x2 piece of wood to flatten the pipe.
I bought 2pcs Stainless steel bushings to insert into the PVC wheel mount to reduce friction wear.
I used 1/2 PVC pipe for the upper framing. The floor base frame is 1" PVC pipe...
I have not glued it yet but after some minor tweaking, I'll finish it and update this instructable.
The Skin...
As soon as I get some, I'll be riveting Coroplast (corrugated plastic 4' X 8' X 4mm) as the skin for the floor, sides and wheel fender. Home Depot sells sheets for about $13.
Fittings I used are as follows...
- 2pcs - 1" 90° Elbows
- 4pcs - 1" 45° Elbows
- 1pcs - 1" 4-way fitting
- 5pcs - 1" T's
- 10pcs - 1" to 1/2" T's
- 2pcs - 1/2" 90° Elbows
- 8pcs - 1/2" 45° Elbows
- 2pcs - 1/2" 4-way fitting
- 8pcs - 1/2" T's
Hope this gives ya'll some good ideas on building your own trailer! Again, sorry this incomplete.
If you have any questions, I'll try and get back to you soon...
Be the First to Share
    • Metal Contest
      Metal Contest
    • Back to School: Student Design Challenge
    • Cheese Challenge
      Cheese Challenge
    9 Comments
    aa77260
    aa77260
    Question 1 year ago on Step 2
    Could you answer to the previous question? I'm interested too!
    Mick504
    Mick504
    Question 2 years ago on Step 1
    How did you attach it to your bike?
    RicoR13
    RicoR13
    4 years ago
    how strong is this how much weight can you put on it? witout breacking
    dimaspin
    dimaspin
    5 years ago
    How much weight can it carry?
    foothillbilly
    foothillbilly
    5 years ago
    I would like a picture of the bushings with the wheel fitted if that's possible. Also, please show and explain your hitch.
    Ingenerare
    Ingenerare
    5 years ago
    Looks Great! Is t strong or does it rorate when it is loaded?
    mahonri
    mahonri
    5 years ago
    This looks really good! Could you provide details about the hitch you are using to connect to your bike?
    seamster
    seamster
    5 years ago
    This looks cool. I'm curious to see the full details when it is completed.. I hope you'll update! :)
    I'm wondering about the bottom. Will you be adding a board of some kind to create a "floor" to load gear onto?
    DIY Hacks and How Tos
    This looks really impressive, especially because you made it with PVC.
