DIY Pcb Hand Drilling Machine
Intro: DIY Pcb Hand Drilling Machine
hello all,
This is my first instructable.
I am just a hobbyist who interested making circuits and their pcb's in complete DIY manner.i saw lot of articles of home made PCBs.they were quite good except one step.making holes for mounting components.start from laser printing the PCB layout to mounting the components you can carry out in home except the drilling procedure.you shld have a drilling machine with small drill chuck,which is capable of holding 0.5-1.5 drills.
Then i had in my mind,why not DIY PCB Hand drilling machine.
My goal is to built one from junk which is capable of drilling small holes to mount components.
Remember this is not sort of professional drilling machine.with it u can just make holes small enough to mount electronic components over PCB.
Finishing of the drilled holes will depend up on the type of drill you used.(made)
Below is my PCB hand drill and my PCB making setup.
STEP 1: Stuff Needed
This is what u need to built a PCB Hand drilling machine.
1. 24v DC motor (takes from old dot matrix printer)
2. Nylon pulley (from printer only)
3. Mounting screws 3mm (these are used to mount mother board in CPU cabinet)
4. 3mm hardened screws (2-2.5 Inch in length)
5. 24V supply,some basic tools,Grinding machine with Rough and smooth wheels.
STEP 2: Procedure
Making drill bits:
Take 3mm hardened screw and cut off its head.then use a smooth grinding machine to grind it as shown in the below picture.this step require little experience of grinding operation.
In the picture drill 2 is not good.it can make hole but the finishing of the hole will be bad.as its area increased from tip to the end .where as drill 4 has same area from tip to end.so with it u will get exact circular hole.
In the another picture u'll find different types of drills.(sorry for such bad pic i was in hurry so had use MS paint)
drill 1 has circular edge so u have to apply lot of force to drill hole where as its grinding is easy.
drill 2 has square edge.so there will be 4 cutting faces.with it u'll get good hole but its hard to grind.
same with drill 3 but instead of 4 it has 3 cutting edges.
so you have to experiment ,which one is good and suitable to you.
STEP 3: Assembly
Now start assembly
take the nylon pulley and try to create internal threads.for this u don't need any spl. tools.take 3mm screw and tighten it in to the pulley with little force.as the pulley is made of nylon internal threads will be created by that 3mm screw.now unscrew it and fix the mounting screw firmly.
then fix the previously made drill bit inside the mounting screw.now insert this hole assembly in to the motor shaft.
*If my explanation is not clear please follow the pictures below.
Voilah! your home made drilling machine is ready.before going to drill ur PCB,test it on a waste piece.so that you can confirm which drill is good and with which ur getting good finish.
some points that i want to repeat
1.This is not professional type drilling machine.
2.hole finishing will depend up on ur tool(i prefer square type drill).so make it carefully
3.try to get motor with High RPM and some good torque.
Have a look at the drilling operation sample video
As i said before this is my first instructable,so let me know abt my mistakes.
Regards
Regards
28 Comments
UtkarshVerma 7 years ago
For those who are still struggling with it, try my instructable:
https://www.instructables.com/id/Handheld-PCB-Dril...
PerryinjaxB 8 years ago
Can I heat the tip of a safety pin and punch a hole in my PCB since I only need to do it once and do not care if the hole is a bit sloppy?
Why not just grind flat two sides of the motor's shaft? I have so many tiny electric motors from the tail motor of crashed mini-helicopters that once it goes dull I could just grind a new one on a new motor. Would that work? Or is it necessary to use the threaded screw for a reason I am not thinking about? Btw- I do realize that I would need to keep the heat down while grinding in small steps, off then on again on the grinding wheel to keep from melting the brushes the shaft is connected to inside the motor. But what about other than that, any reason why it wouldn't work just as well, and get to avoid the making of the "chuck"? Maybe one could even use a small hand file to file some kind of sharp edge on the end of the shaft? IDK
arupbsk 12 years ago
But is there any wat to attach our normal titanium drillbits into the motor?
ac-dc 11 years ago
If you wish to try using them anyway, use a "dremel tool" (rotary hobby tool) since it is essentially a handheld motor with the chuck and collet needed to align and attach the drill bit to the motor shaft in a non-permanent way.
Ortzinator 11 years ago
Spaceman Spiff 11 years ago
glorybe 11 years ago
tony54 12 years ago
You need to use a FIXED drill at as high a speed as possible. Commercial drilling machines use 50,000 - 100,000 RPM. Since that isn't something the average person can find or afford, use at least 30,000 RPM with a Dremel and if possible replace its' bearings with BETTER bearings. Use in a Dremel drill press or make your own version but you shouldn't tilt more than 1 degree. You can be more relaxed if you are only drilling large 1/16th inch or larger but smaller bits and parts REQUIRE the accuracy.
Also, you can get CARBIDE PC board drill bits for around $1 - 2 each used. They are much better that new high speed steel but don't tolerate side movement. They will break like glass if much side force is applied.
I used to work designing and manufacture commercial PC boards so I know from what I'm doing.
diy_bloke 11 years ago
spawnos3717 12 years ago
coder512 12 years ago
margrove 13 years ago
https://www.instructables.com/id/PCB-Drill-Press-Using-Salvaged-Door-Hinges/
It works really well.
By the way, I had no trouble with your English. For a first instructable you have done remarkably well. Let's have more!
beehard44 13 years ago
Mr. Smart Kid 17 years ago
PyroMonger 15 years ago
