Introduction: DIY Portable Charger
its a pain when your phone battery is low and you have to do some work and there is blackout then how will you charge your phone then you will use this emergency charger which will give a an extended juice for your phone with a 9v battery
so without further lets do this
Step 1: Tools Needed
7805 ic
micro usb cable
9v battery
9v battery connector
and some basic materials
this is all you needed to do this
it costs around 1 $
thats cheap it is
Step 2: Heat Up the Soldering Iron
just cut the usb in hald and connect the each wire as shown above
note before powering your phone with it just take a multi meter and check the voltage it should not excced from 5.2
otherwise your phone may be damage
Step 3: You Are Already Done
that how easy and simple it is to make a emergency charger
check this out on youtube at
check out our channel at
https://www.youtube.com/channel/UCgdTN9c6dVWrnffGs...
and also check out our page
https://www.facebook.com/techyguy301/
like and share
6 Comments
6 years ago
how much charge can the 9v provide?
Reply 6 years ago
This can provied from 100 to 500 mah depending on the battery type and juice left and also on the ic if it is 7805ic then 100 to 500mah
But if it is a 78l05 transistor then it can give from 500 to 1000mah
Reply 6 years ago
Just a small correction, the 78L05 'transistor' is not a transistor at all, it is exactly the same thing as the lm7805, just smaller and in the same package as many small transistors. While it is slightly more efficient than its bigger brother, the 78L05 can only output 0.1 amps, and the lm7805 can output up to 1.0 amps. Since a phone can, theoretically, draw over an amp, using the 78L05 is not a very good idea.
Reply 6 years ago
The LT7805 "cuts" higher Voltages then 5V off. So you will lost 9-5=4V
The current will be the same as before (minus the losses)
Example: 9V-Battery with 1000mAh (1Ah)
Energy stored in Battery: 9V*1Ah = 9Wh
Energy after LM7805: 5V*1Ah = 5Wh (you still have to subtract the losses)
Capacity in the smartphone battery (average Voltage = 3,7V ): 5Wh / 3,7 V = ~1,35Ah = 1350mAh
In real life you will have higher losses so maybe it will restore 1000-1200mAh
But most of the energy will be transformed into heat so it's not very efficient
It's more efficient to use a Switching Regulator instead of a Linear Regulator
Reply 6 years ago
thanks for the explanation . I will plan on my phone lasting one hour after I charge it with the battery.
Reply 6 years ago
Thanks bro for your help and by the way i am only 15 and i have telled him what i have dicovered with this project sorry for any wrong information
And also thank you for telling me this and i will try to make a project with more efficient this month
