DIY: Prototyping Cables
Intro: DIY: Prototyping Cables
You have seen these cables everywhere........
you might have them ............. you might not
but wouldn't you love it if you could attach to a wire of Ur choice
or even better make then from scratch your self???
here is a simple yet almost free way of making these cables
you could buy them from various shops and online stores but that requires either waiting for it to arrive
or you going and buying it personally.
NOTE: This works on multistrand ( multicore) wire ..... i have not tried on single strand ( single core ) wire and i don't intend to
P.S this is my first instructable.
STEP 1: So What's Needed Again???
You must be having everything at your desk right now!!!
wire ( duh)
bell pins
breadboard ( optional)
arduino ( optional)
wire strippers ( optional)
the arduino i have is called an Induino ( India+arduino)
it is an Indian clone of the amazing arduino
http://www.simplelabs.co.in/content/induinox-low-cost-arduino-usb-clone-board
check it
wire ( duh)
bell pins
arduino ( optional)
check it
STEP 2: Procedure
Its very simple to make ........................
take ur wire
strip it
twist it
wrap it around your pin
push it back and make sure its tight
and ur done
take ur wire
strip it
twist it
and ur done
STEP 3: Going Further!!!
You want to make it permanent ?.................. solder it on
go ahead and modify it to your liking
go and enjoy the world
oh yeah please rate it!!!
7 Comments
russ_hensel 9 years ago
Just a note to let you know I have added this ( a year ago ) to the instructable:
Comprehensive Guide to Electronic Breadboards: A Meta Instructable
>> https://www.instructables.com/id/Comprehensive-Gui...
Take a look at a bunch of ideas for using breadboards.
shreyans29 11 years ago
agis68 12 years ago
maewert 12 years ago
As a finishing step I would want to apply some heat shrink to maintain the physical contact, especially if you do not solder the wire to the pin.
Another alternative method would be to create a wire-wrap tool that fits the pin. This would ensure the wrap winding goes on tight and up next to the pin head.
Have you found these to be as reliable as the store-bought ones? I could see the benefit of making them yourself if for some reason the manufactured ones are not available in your country or if you are in a pinch. Otherwise I'd think the manufactured ones are pretty cheap and are so reliable there is no need to make your own. The chance of a loose connection ruining your whole day is too great in my opinion.
Best Wishes.
akinich 12 years ago
As of rite now the manufactured ones are still on their way ( stuck in shipping)
they are not available locally and my electronic components are in a box.
i am shifting right now so i needed a quick fix!!!
one advantage to this is you can make any length you require
you dont have to go through your cables to get the perfect size
thanks for the advice
Kozz 12 years ago
