DIY Rotary Tool
Introduction: DIY Rotary Tool
In this instructable, I will show you how you can take some easily available materials and combine them to make a DIY rotary tool! So lets get started.
Step 1: Materials
This is a very easy project and does not require a lot of materials. The materials required are:
A 12V DC motor
A switch
A DC jack
Some wires
And a drill chuck
Step 2: Connections
Connect the motor, switch and the DC jack together, you can refer the images for this. The connections are as follows:
DC Jack + to Switch to Motor
DC jack - to Motor
Step 3: Enclosure
You can make the enclosure in many ways. Here's how I made mine. I used a plastic tube and drilled two holes, one for the motor and one for the switch.
Step 4: Finishing
Put the motor in the enclosure and secure the switch in place. put the chuck on and its done. you just made your own rotary tool. This is compatible with all dremel attachments. Have fun building yours!
Please vote me in the make your own tool contest
Build a Tool Contest
Be the First to Share
    • Fix It Speed Challenge
    • Raspberry Pi Contest
    • One Board Contest
      One Board Contest
    gralan
    gralan
    2 years ago
    I'm just gonna have to make this merely for the sake of doing it. Thanks.
