Introduction: DIY Shabby Chic Painted and Distressed Table Bench
DIY Shabby Chic Bench Table
My customer had this beat up reproduction bench/ table. I believe the style is called a “telephone seat” but not sure. Anyway, she wanted to clean it up, paint it and give it a shabby chic distressed look. The piece has a lot of detail carving that she wanted to accent and did not want a heavily sanded look.
Materials Needed
Blue tape
Drop cloth
Apron
Gloves
Paint brushes and small roller
Sand paper
file
Rustoleum clear satin finish
Primer
Antique White Paint
Step 1: Step 1
Step 1
This piece had some upholstered areas. She liked the fabric so we had to mask those areas off. This is the stage to fill any imperfections with spackling or wood putty. Once any filled spots are dry, all the wood sections get sanded so the paint will adhere better. I went over everything with a dust cloth.
Step 2: Step 2
Step 2
Prime all the wood parts. I like water based products because of the quick drying time. Primer is quick and you can usually follow up with paint in about an hour. I gave it one more coat after that and then let it cure over night.
Step 3: Step 3
Step 3
This piece had a delicate look with some intricate carving. I like to use a file for removing paint. It is not as harsh as sanding and you have a bit more control over delicate areas. I would still go over the areas with fine sandpaper I used the file on to soften any sharp spots or burrs. Once again go over the piece with a dust cloth.
Step 4: Step 4
Step 4
It is important to top coat the paint with a clear finish. It will help it wear longer and give you a washable surface that won't smudge. The clear coat also brings out the color of the exposed wood. I like two coats at this stage and any top flat surfaces a third. Rustoleum clear finish has become my favorite. It dries quick, levels well and clean up is with soap and water. I've tried other brands but this one works really well for most indoor projects. Once everything is dry remove the blue tape and touch up any spots you missed.
Painting and distressing a piece of furniture is really easy. I hope you have enjoyed this Instructable. Please send me any questions or comments and again thank you for reading my Instructable!
