DIY - Single Use Antibiotic Ointment Blister Packs
Intro: DIY - Single Use Antibiotic Ointment Blister Packs
The ongoing trend in the consumer market of providing small, ready-to-go, individual size packages of consumables has been a win-win for the lightweight and ultralight backpacking communities. Always looking to shave a few extra ounces or grams off of our overall pack weight, these individual servings are the perfect fit for trail snacks, drinks, condiments - you name it.
However, these nicely packaged individual servings can come at a premium. They can often be pricy or difficult to find without going online and ordering in bulk +shipping. That's when the creative types among us come up with ingenious solutions that lets us make our own alternatives using things we usually have lying around.
STEP 1: What You Will Need
I've carried a few of the Neo-to-go (Neosporin) packets with me as part of my first aid kit for quite some time. They're small, handy and easy to use, but they have some downsides. Firstly they are quite expensive, secondly each packet contains way more ointment than I need for a small cut or graze - an awful lot more and once it's been opened it shouldn't be reused or saved.
So here is really clever solution to this problem that involves a tube of antibiotic ointment (generic), a plastic drinking straw, a Bic lighter and a pair of needle-nose pliers. We're going to make very small, single use packets of antibiotic ointment using a generic alternative to Neosporin and a clean (unused) drinking straw. If you're like me and have kids, chances are very good that you have an open tube of antibiotic ointment in your medical cabinet already. On its own it is too large to carry on a backpacking trip, so we're going to re purpose it.
STEP 2: Filling the Straw With Ointment
Place the straw over the opening of the ointment tube and carefully squeeze in a small amount of the ointment that is approximately one quarter of an inch in length. You'll notice that transparent straws work best for this.
Use you fingers to squeeze the end of the straw so that it pushes the ointment further up inside the plastic straw. This will provide a clean area for sealing the end of the straw without having the ointment ooze out while you are holding it with your pliers.
STEP 3: Sealing the End of the Straw
Hold the end of the straw with your needle-nose pliers so that a small amount of the straw is protruding. This will be used to melt and seal the end of the straw. Take your Bic lighter and carefully melt the end of the straw so that it forms a seal. I like to quickly pinch the melted end with my pliers to ensure a good seal.
STEP 4: Cut and Seal the "packet"
Turn the straw around and find the point where the ointment went up to inside the straw. Pinch just past that with your needle-nose pliers and cut off the excess straw with a pair of scissors making sure to leave a small amount of the straw protruding for sealing with your lighter just as you did in the first step.
STEP 5: The Final Result
Now you have a single use packet of antibiotic ointment that you can carry with you as part of your UL backpacking first aid kit. These are also perfect for EDC carry in a pocket or even your wallet.
I've yet to have one of these burst or fail on me. Simple, affordable, and very convenient. A great way to make use of those open tubes that are lying around with just a small amount of ointment left in them. Pretty clever idea that can be used for a myriad other purposes, what do you think? [Re-published from Brian's Backpacking Blog]
STEP 6: Vote for This in the Pocket-Sized Contest!
If you liked this instructable or found it useful, please consider voting for it in the Instructables.com Pocket-Sized Contest. All you have to do is to click on the "Vote" button in the upper right corner of this page. I would greatly appreciate it :-)
72 Comments
ScottyGS 11 years ago
Now --I have a great site to show him a reason for us to save a few --but is there a place I could forward some on so others like you can benefit from them? I actually have a couple which are HUGE --5-l/2x2 which I might keep for myself (unless I get more) to fit actual tools (small screwdrivers and the like-- since I work on my harmonicas when I travel). But I also quite frequently get the fatter bottles: 2-3/4 x 2" which would fit a bit more and still be lightweight and waterproof. Those might be just the thing for those interested in creating 'kits' to send on to troops in the field if anyone wants to start this up as an idea? I'm sure there are many more people out there like me who'd be happy to forward on our empty bottles although having a foolproof way to remove the labels without leaving sticky residue would be great.
LaserDave 9 years ago
I realise that this response is two years too late, but I felt that
my contribution would be helpful to lots of people who face this
side-issue you've mentioned.
In this day and age where the issues
of environment and identity theft are forefront, many people are faced
with the problem of being able to recycle their medication bottles but
cannot easily remove the labels. Having to choose between recycling and
privacy, the solution most people choose is to dispose of these bottles
in the garbage. Some people will spend the time and energy it takes to
remove the labels, but it becomes a daunting task when it involves more
than a few bottles.
The solution I came up with was out of
necessity, having to de-label more than 30 bottles from the
prescriptions of three people each month. Soaking them in a bucket of a
mixture of water and WD-40 worked well, but there had to be a better
way. After devoting an entire afternoon to find an easy, reliable and
fast method to do this, I settled on the following...
A square
piece of cardboard, twisted and taped it into a cone like a funnel, I
used a $10 hair dryer (or a heatgun) and directed hot air into the pill
bottles one at a time. After a few seconds, the bottle would be
sufficiently warm and the labels peeled off cleanly once the glue
relaxed. I found that I was able to do twelve or so bottles in about
four minutes. In fact, I was amazed at how well the method worked once I
got the timing figured out, and now those 'welded-on/permanent'
prescription labels are no match for me.
Now the bottles can be
put into the recycling, or repurposed for use in crafts, or even as
storage for small nuts and bolts or other tiny parts. Hope this helps!!
ratgirl13 10 years ago
TheHumanWhiz 10 years ago
cassandrabutt 10 years ago
This is an amazing idea, the only hangup for me is I'm trying to cut out as much plastic from my life as I can. Would you be able to do this with a paper straw and then seal it in wax? Or do you have any biodegradable ideas you can share?
Thanks so much for the ideas! Love it!
bpfh 11 years ago
Trigonography 11 years ago
bakdrft 11 years ago
bfgreen 11 years ago
C'mon, be nice and be constructive with your comments or please don't leave any.
Thorsword 11 years ago
john0214 11 years ago
mttrout 12 years ago
-Lotion
-Sunscreen
-Hydrocortizone Cream
-Neosporin
-Advil
-No Crap / No Nausea / Dramamine Pills
-Allergy Pills
-Shaving Soap
It cut down my bathroom kit to a sandwich ziploc bag. Quick question...anyone gone through TSA security with these?
ejarrell 11 years ago
firefly2 12 years ago
Perhaps another way to "make" the straw package.....seal the first end of the straw (without ointment ) since you ultimately have to seal a short length anyway. Clean the tubing, trial fit it in advance. Ointment would probably move through a syringe w/o a needle or through a big needle. Deposit the ointment in the far end next to the first seal, making it easier to complete the final seal. I can't tell what size tubes to get or where to get them from. Just keep them when you find something useful....Creative Engineering! Hope it works. Thanks for all the other ideas.
Terri1ND 12 years ago
cdltpx 12 years ago
Papillon9 12 years ago
myckro 12 years ago
