Introduction: DIY Smartphone Notification Lamp
Introduction
So many gadgets for your smartphone, but it's not cheap for you buy it. So now i will show you how to make unique gadget for your smartphone for cheap and under 30 minutes to make it. I will make Smartphone notification lamp because its so useful when i have new notification or any new message and this gadgets can use as flashlight.
Let's Make It!!
Step 1: Tools and Materials You Will Need
Materials:
- Old audio jacks (Use 3.5 mm jack)
- 1 Low voltage LED (Use the low voltage led for best result)
Tool:
- Soldering iron
- Hot glue gun / any glue for make the case
Step 2: Open the Case
Take the audio jack and open the case slowly, Don't broken the inside.
Step 3: Search the Output Voltage
- Take your smartphone
- Plug in the audio jack
- Listen any music on your smartphone and set the volume full.
- Paste the led and search the positive and negative output
- And its look like image 4 and 5
Step 4: Solder It!
Take your soldering iron and solder it slowly. After that its look like image.
Step 5: Make the Case
Make the case for looking best. I use hot glue to make the case like image.But you can use anything for make the case. And cover it using heat shrink tubing or anything. I use white tape to cover it.
Step 6: Finish
- Plug in this gadget to your smartphone
- Set the audio volume on your smartphone full
- And if you get new Notification or new message, the led will on
- To see how it works, watch the video
Step 7: Thanks
All finish, I hope you enjoy this. Don't forget to like, subscribe, and vote me :)
Sorry for my bad english.
Thanks
Runner Up in the
Maker Olympics Contest 2016
Outside Contest 2016
Summer Fun Contest 2016
1 Person Made This Project!
- KISELIN made it!
20 Comments
6 years ago
not a bad idea. I wonder if it could be done with an rgb led
6 years ago
Does this light work on Iphones, I noticed you have a samsung and when I assembled mine, the LED never lights(polarity is correct and wiring is correct) And when tested the jack should drive enought power to light the LED (I tested a 1W 8Ohm speaker which worked on the jack.) But the LED never lights even when I know the jack is working. I also tried multiple LEDS.
I have an iPhone SE.
6 years ago
Nice thinking! If you use a headphone splitter you can still use your headphones while getting LED notifications.
This would be great to bring to the library!
Reply 6 years ago
Thankss
6 years ago
It doesn't work. Can't even strip the plug !
6 years ago
mantap gan...
Reply 6 years ago
Terima kasih!
6 years ago
Maybe a stupid question. Do you plug out when you answer the call? I think speaker and microphone will be off when it is plugged in.
Reply 6 years ago
No. you can loudspeaker your call
6 years ago
I suspect this will only work if you have some kind of notification sound enabled with enough energy to light the LED. For instance the Pop on my droid probably won't work.
6 years ago
So, dumb question: the power for the LED comes from the audio signal traveling through the audio port, right?
6 years ago
This is really neat. I like it. It would be cool to use RGB LEDs and watch how the LEDs mix colors with the notification. I think I'll try it!
6 years ago
Cool enough.. to be a 'ible Yeah. but...... where do you put this gadget when you wanna plug in your headphones? :) By the way.. I'm irritated of there to be these plugs, (jack's), of several dimensions like 1,4mm 1,8mm 2,1mm 2,4mm 2,8mm........3,1mm ...6,0mm. hmm......
6 years ago
I wish to correct the author:
"Old audio jacks (Use 3.5 mm jack)"
That is the wrong item or description. The correct item is a plug since the jack is already in the smartphone. I recommend correcting this error soon because I may be the first of many comments about this error.
6 years ago
Wow! this so clever! NIce job bro I'm gonna try this!
Reply 6 years ago
thank you. yes, you have too :)
6 years ago
Excellent. My iphone 6 s plus has this feature under accessibilty. I love it and it is very useful, especially when I am in a noisy setting and wouldn't hear the notification. I can easily see this in my pockets and purse's outer pocket.
Reply 6 years ago
Thanks. i hope you enjoy this. Happy making
6 years ago
This is so cool yet so simple! I bet it can even activate other types of things haha
Reply 6 years ago
thanks for look my works. happy making!
