DIY Switch Adapted Bubble Blower
Intro: DIY Switch Adapted Bubble Blower
This project is designed to adapt a bubble blower so that it has switch access.
STEP 1: Remove Screws
Remove the six screws from the back of the toy. (Note: you will not have to remove any of the screws from the tail)
STEP 2: Add Hole
Melt or drill a hole into the very back of the toy to allow enough space for the cables to fit.
STEP 3: Cut Cable
Cut the end of the cable. (We will be using the female end for this adaption).
STEP 4: Strip Cable
Strip the cable so that there is approx. 4 inches of the red and white cable showing.
STEP 5: Strip Cable Again
Strip cable so that the wires from both the red and white cables are showing. (Note: only strip a small portion of the cable)
STEP 6: Solder
Add solder to the ends of both the red and white cables.
STEP 7: Thread Cable
Thread the cable through the back of the toy. Tie or use a zip tie to prevent the cable from being able to be pulled out.
STEP 8: Solder Part 1
Solder one cable to the area shown in the photo.
STEP 9: Solder Part 2
Solder the second cable to the area shown in the photo.
STEP 10: Reassemble
Reassemble toy.
STEP 11: Enjoy
Add switch and enjoy!
