DIY Tazer
Intro: DIY Tazer
In this instructable, i will teach you how to make a very effective tazer out of a bug zapper .
WARNING!
Do not use this on anyone with a weak heart or pacemaker!
WARNING!
STEP 1: Step 1: What You Need
You will need:
A bug zapper
A 9 volt battery clip
A soldering iron
Solder
9 volt battery
1 Blue led ( or any other color )
1 100 ohm resistor
1 220 ohm resistor
Hot glue gun and glue
Wire cutters/ strippers
Wire
Screwdriver
Wall adaptor ( see image )
A bug zapper
A soldering iron
Solder
9 volt battery
1 100 ohm resistor
1 220 ohm resistor
Wire
Screwdriver
STEP 2: Step 2: Start
Start by unscrewing the screws holding the handle together, make sure to keep these.
STEP 3: Step 3: Remove the Zapper
Now cut the wires going to the red section, make sure to kep some length.
STEP 4: Step 4: Take Apart the Adaptor
Now unscrew any screws from the adaptor, pry it open and remove the metal. Now cut excess metal, keeping the prongs. ( second picture )
STEP 5: Step 5: Solder
Now solder the prongs to the wires.
STEP 6: Step 6: Cut and Solder.
Now remove the old battery connections. Cut the mounting for batteries, and cut the Springs from the wires. Now solder the 9 volt adaptor. Negative to the board, and positive to the switch.
STEP 7: Step 7: LED
Now solder the resistors In Parallel, then solder them to the LED.
STEP 8: Step 8: Glue
Now glue the prongs to the opening at the top of the handle.
STEP 9: Step 9: Solder
Now solder the resistors to the switch, and the LED to a wire coming fron the circuit board.
STEP 10: Step 10: RE-Assemble
Now glue the circuit board into place, fit everything snugly, and screw it back together.
STEP 11: Step 11: Your Done!
You now have your very own mini-tazer
STEP 12: Video(s)
Here are some videos of the tazer, I'll add one soon of me tazering my friend. ( it'l be great! )
STEP 13: Random Fact
Did you know that taser stands for Tom A. Swift's Electric Rifle. Yes i know the title izzz wrong, but it sounds cooler!
STEP 14: Final Note
Thank you for viewing my instructable. Please feel free to leave any comments or suggestions, they are appreciated.
53 Comments
whisperingsage 6 years ago
mylsss 7 years ago
If i want it to lessen the output voltage, what will I change or remove?
zain_de 8 years ago
does it produce sparks or continuous voltage?
Varrma 9 years ago
Can i put a more powerful resistor so that the zapping power reduces and it doesn't hurt much.
chala.ranjith 9 years ago
how it hurts?
MEEEEEEEEEEEEEEEEEEEE 10 years ago
also I definitely could not do any of this without getting caught
what was the battery about?
freeza36 12 years ago
XOIIO 12 years ago
lemonie 14 years ago
XOIIO 14 years ago
XOIIO 14 years ago
frollard 14 years ago
XOIIO 14 years ago
XOIIO 14 years ago
natman3400 13 years ago
XOIIO 13 years ago
