DIY Tooth Brush Robot
Intro: DIY Tooth Brush Robot
here I'll show you how to make a tooth brush robot out of a few simple pieces, I know theres been a lot of other ible's of the same thing but mine is a bit different and can be charged over and over. this is my own design of this robot, you need:
Supplies-
-Mini vibration motor
-Capacitor
-Tooth brush head
-glue gun
-9v battery
Supplies-
-Capacitor
-Tooth brush head
-glue gun
-9v battery
STEP 1: The Set Up
First you are going to wire everything up. I just soldered the motor onto the capacitor, but id you dont have a capacitor then connect the motor to a small battery. you can also add a switch if you want.
STEP 2: Attach the Head
now glue your motor and electricity source to your tooth brush head, I cut the middle strip of bristles off then I glued it to the bottom for the first type, for the second type i glued it to the top. the first type works alot better because of the angle bristle heads. the second type falls over more and just spins around most of the time.
STEP 3: Let It Loose
now either charge your capictor or connect the battery to your motor and let your robot loose!
Enjoy!
Enjoy!
28 Comments
ALOKS1 9 years ago
Cool!! And what about the Capacitors? Can I do without the CapaCitor? I mean a small battery Cell will be okay? And CapaCitor needs to be Charged often right?
wolf-y 13 years ago
LorditaM 9 years ago
i will do it also
very nice robot i made a robot made of can !!!
mintar 13 years ago
Lucky7x7 11 years ago
Emsaid 13 years ago
mintar 13 years ago
wsanriv 13 years ago
Nice little bot :D
robertjames 12 years ago
Cadet 13 years ago
Emsaid 13 years ago
rowow 13 years ago
Emsaid 13 years ago
jefersonrod 13 years ago
neffk 13 years ago
uberhund 13 years ago
However, niCads have nasty habits also, so I'm inclined to think it's a rechargeable battery of some sort.
But why no polarity indicators on the packaging, in either case? I still don't get that. I'm not going to buy an Airhog to find out.
Emsaid 13 years ago
Emsaid 13 years ago
