DIY USB-PD Powered MCH Automatic Reflow Hotplate (Open Source!)
Intro: DIY USB-PD Powered MCH Automatic Reflow Hotplate (Open Source!)
As an electronic maker, it is getting harder and harder for me to create new projects as parts (mostly IC and surrounding components) are getting smaller and smaller. About 10 years ago, SOP package IC are still easy to find which range from supporting USB2.0 or Serial communications. But in recently years, most ICs other than those require heat dissipation like battery charging or power management ICs, signal ICs are hard to find in SOP packages.
Design GoalAs I always to make something else other than power banks, I need to figure out a way to make soldering smaller packages IC less painful. The issues is that unlike makers from other country who usually have a larger space to work with, I live in cities with workspace smaller than a toilet in western countries. That is why I need to find a solution that is
- Small, compact
- DC powered (as I don't feel comfortable working with AC)
- Fully automatic reflow like an infra-red reflow oven
I did try to look for some solution on the internet, the closest I can get is either a proper reflow oven or those tiny rework hotplate that uses PCB hot-plate, which do not met my requirement regarding my "dream reflow stations".
That is why I decided to make one myself. Though, this is one of my most expensive and hard to complete projects in recent year due to complexity in material sourcing. I will share with you in details in later steps.
What Make This Build Special?This is probably the first open source USB-PD powered MCH hotplate on the internet, even featuring the automatic reflow profile for Sn63Pb37 but not other specific solder paste design for low temperature reflowing.
The issue is that MCH hotplate is a bit tricky to get and finding one with specific specification always require custom made. This design factors in the difficult of souring such components and design the hotplate components to be swap-able with a PCB hotplate or MCH hotplate with different spec. Just change a few lines of code in the firmware to control the power switching frequency (and hence, adjusting the power to the hotplate), this PCB design basically fits most of the heating element you can find online with suitable sizes and power rating.
STEP 1: 3D Print the Mounting Base
First you can start by 3D printing the base. It is a simple step. Just get the stl file, slice it and send it to a 3D printer.
STEP 2: Send the PCB to Print
As the PCB is the main component of this build, you can order your PCB at any PCB manufacturer you preferred. This project is sponsored by JLCPCB. If you have never tried to order a PCB before, please feel free to try out JLC services with the link below.
In my case, as the MOQ of the MCH hot-plate is 50 pcs, so I order a bunch of them from JLC so that I could make a few more of them and give them away with only the material costs.
You can find everything you need for the PCB over here on my github repo.
https://github.com/tobychui/MCH-PD-Automatic-Reflow-Hotplate/tree/main/pcb
Side Note
In this instructable, I am using the v3 design but later I found that adding a small 0.1uF caps over the output of the L7805 improve the overall stability when using cheap / low quality GaN charger with large ripples. This is optional but I recommend adding it if you are making one for yourself.
STEP 3: Laser Cut the Hot-plate Support Structure
The hotplate support structure is a piece of 3mm MDF that is wrapped in Kapton tape. This prevent the MDF from smoking and turning black after long period of uses.
STEP 4: Assemble the Temperature Sensor Element
The temperature sensor (glass bulb part only) is glue to the back of the MCH hot-plate with heat-sink adhesive. Note that there are a lot of S922 heat sink adhesive clone out there that cannot handle the temperature stated in its datasheet. So make sure you get them from a seller with good reputation.
You will want to place the thermistor on the bottom side of the MCH and fix it in place with a piece of Kapton tape. Next, slightly bend the glass bulb so it is touching the surface of the MCH. Finally seal if off with a glob of heat sink adhesive.
STEP 5: Assemble the Heater Support Structure
Screw the 4 M3 stands off into the PCB and secure them with M3 nuts. Next, fix the MDF heater support structure on top of the stand offs. Make sure not to screw it too tight and leave some space for the thermal expansion.
After complete, you will see something like this as shown in the photo above.
STEP 6: Glue the MCH Hot-plate in Place
Use K-704 heat-proof silicone adhesive to glue the MCH hot-plate in place. Make sure to give it a generous amount of glue and make sure all the surface where the hot-plate is touching the MDF is covered with a thick layer of heat-proof glue. If you do not give it enough heat-proof layer, the heater will fall off after a few uses and you will need to redo Step 3, 5 and 6 again to replace the Kepton adhesion layer.
Wait for the glue to dry before proceed to the next step.
STEP 7: Solder the MCH and Thermistor to the PCB
After the glue dry, you can route the leads of the MCH through the two large circular holes near the square hole to the back side of the PCB and solder the hot plate power wire to the PCB from the other side.
For the thermistor, you will need to use a lighter to burn off the outer protection layer and expose the inner conductive metal layer before soldering them to the sensor pins on the PCB.
Make sure the two thin wires of the thermistor do not touch or get any close to gether. Otherwise, this might effect the reading of the MCH hot-plate temperature.
STEP 8: Flashing the Hotplate Firmware
I am assuming you have basic knowledge on how to use Arduino IDE and install new boards from board manager.
You will need to install this board manager in order to flash the firmware to the hotplate.
https://github.com/DeqingSun/ch55xduino
If your chip is new and there are no code inside, you can flash it directly via the USB 2.54 pins at the bottom of the PCB. As I am lazy at soldering 50 boards I am making, I bought a custom pogo-pin flashing tool to help me with that. However, you can also just solder a standard USB 2.0 (male) header to the pins and plug it into your computer's USB port.
If your CH552 has been flash before, follow detail instruction on my Github repo for overwriting the build-in firmware.
The recommend board settings are as follows.
- CH552
- 16Mhz (internal, 3.3V or 5V)
- Upload Method: USB
The firmware can be found over here
https://github.com/tobychui/MCH-PD-Automatic-Reflow-Hotplate/tree/main/firmware/reflow
STEP 9: Thermal Testing
In order to test the hotplate, screw the base to the PCB assembly and stick a temperature sensor to the surface of the hotplate with Kapton tape.
Press and hold the "START" button to start reflowing. The yellow LED should start fast blinking indicating the reflow will start in a few seconds.
For detail usage guide, see here
If everything is working, the temperature will peak at around 235 - 245 degree Celsius when the hotplate entered reflow stage. Note that the temperature on the hotplate is slightly hotter than what is recommended by the reflow profile as it is not a reflow oven but an open-air hotplate which I need to accounts for thermal lost to surrounding.
If the reflow seems completed, you can always early-stop the hotplate by pressing the "STOP" button.
STEP 10: Reflow Test
After thermal testing seems great, now you can try reflow something. Here I am using a SSOP chip with an adapter PCB to try out my reflow hotplate prototype. The last photo shows the result of reflow after some cleaning.
STEP 11: Reflow Hotplate Complete!
Now you have completed your DIY MCH PD powered automatic reflow hotplate! (Maybe I will just call its Toby's reflow hotplate in the future as its name is a bit too long :P)
