DIY WIFI RC Car With ESP8266 and Arduino IDE
Intro: DIY WIFI RC Car With ESP8266 and Arduino IDE
This project is an example of remotely controlled car via WIFI. The circuit is based on ESP8266, and the software is written in the Arduino IDE. As an engine driver, I used the L298N. The vehicle's speed is controlled by PWM in the range of 0 to 1023. Digital control offers more possibilities than the usual controller. I also added a RGB LED as light and buzzer as a horn.
This article can also see here:
STEP 1: Components
STEP 2: Schematic
Diagram of a remote controlled car.
STEP 3: Software for ESP8266
Before you upload the software to ESP8266 setup your WiFi connection.
#define WIFI_SSID "" #define WIFI_PASSWORD ""
#include <ESP8266WiFi.h> #include <WiFiClient.h> #include <WiFiUdp.h> #include <ESP8266WebServer.h> #include <ESP8266mDNS.h> #include <Adafruit_NeoPixel.h> #define PIN D8 #define LICZBADIOD 1 Adafruit_NeoPixel pixels = Adafruit_NeoPixel(LICZBADIOD, PIN, NEO_GRB + NEO_KHZ800); //--------------------------------------- #define CMD_NONE 0 #define CMD_LED 1 typedef struct TRCcar{ short speed; short turn; uint8_t flags; uint8_t cmd; uint8_t r; uint8_t g; uint8_t b; }; //--------------------------------------- //const char COMPILED[] PROGMEM = { __DATE__ " " __TIME__ }; #define WIFI_SSID "" #define WIFI_PASS "" int cnt_loop = 0; long time_loop; //--------------------------------------- void setup() { Serial.begin(115200); Serial.println( "\r\n\r\n--------------------------------------" ); Serial.println( "START setup" ); delay(500); BlinkLedSteup(); MotroSetupA(); MotroSetupB(); //--------------------------------- WiFi.mode(WIFI_STA); //WiFi.mode(WIFI_AP_STA); //Serial.print("Setting soft-AP ... "); //Serial.println(WiFi.softAP(GetNameDev().c_str(), "1234") ? "Ready" : "Failed!"); //Serial.println(WiFi.softAP("ESP8266-test", "1234") ? "Ready" : "Failed!"); WiFi.begin(WIFI_SSID, WIFI_PASS); //WiFi.hostname( GetNameDev() ); Serial.print("Connecting to WIFI"); // Wait for connection while( WiFi.status() != WL_CONNECTED ) { delay(500); Serial.print("."); } Serial.println(""); Serial.print("Connected to "); Serial.println( WIFI_SSID ); Serial.print("IP address: "); Serial.println(WiFi.localIP()); //--------------------------------- UDPSetup(); BeepSetup(); pixels.begin(); //pixels.setPixelColor(0, 255, 0, 0); //pixels.show(); Serial.println( "END setup" ); } void loop() { time_loop = millis(); BlinkLed(); SerialEvent(); SerialCMD(); UDPLoop(); BeepLoop(); }Download source code
STEP 4: Computer Control Software
The program I control wrote in C #. For PC communication with ESP8266 I used UDP protocol. All commands are executed immediately without delay. The car is driving great, I think much better than the original controller.
14 Comments
walidber 2 years ago
scotmiller84 3 years ago
viantd 3 years ago
nageswar rao 3 years ago
fenerb 4 years ago
danielv347 5 years ago
MartinK238 5 years ago
AdityaB102 5 years ago
HristoB 6 years ago
amit2017 6 years ago
Bro where is the link or file to
Computer Control SoftwareSUMITMDSEPFO 6 years ago
can you please send the source code for Arduino uno and ESP8266 1
adachsoft 6 years ago
Source code you can download from:
http://geek.adachsoft.com/home/article/id/27/n/DIY...
AhmedI44 6 years ago
thanks man
i just started with nodemcu and so far only your codes seems to work
I am not good at programming
i need help to control it from android device using roboremo app
