DIY Z Axis Slide for Homemade Vertical Mill Router
Introduction: DIY Z Axis Slide for Homemade Vertical Mill Router
Homemade Vertical Mill Router need Z axis, you can hand make it very easy and cheap
Materials:
2 pcs 25 mm Linear Ball Bearing Motion CNC Bearing
2 pcs SHF25 Size 25mm Linear Rail Shaft 400 mm - 25 mm Linear Rail CNC Promotion
2 pcs 25 mm Slide Liear none cover
2 Pcs 200 mm x 70 mm x 12 mm Aluminium Alloy 6061
1 Pcs 200 mm x 65 mm x 16 mm Aluminium Alloy 6061...... make 2 hole 40 mm and 1 hole 20 mm center
More Homemade Vertical Milling Machine very cheap DIY Slide Mechanism CNC here:
Be the First to Share
    • CNC and 3D Printing Contest
    • Lamps Challenge
      Lamps Challenge
    • Rice & Grains Challenge
