DIY Automatic Fish Feeder for Aquaponics
81,354
216
17
Introduction: DIY Automatic Fish Feeder for Aquaponics
Do you have an aquaponic system? Cannot be there the hours that your fish have to eat? Big automatic fish feeders are quite expensive. Have a look how I made mine with 25 euros.
Step 1: The Concept
Here is a scketch of how it works. I found it here. There is a drill that while rotating carries the food out. The drill rotates with a motor and the food is contained in a bottle.
Step 2: Parts List
You will need:
1. a plastic bottle (I recommend you to use a normal water plastic bottle, the one I used was quite some trouble and I had to adjust some cardboard pieces inside)
2. 12 volt DC motor (I used one with gears to adjust the speed)
3. Drill (I made my own drill with a piece of plastic, see next step)
4. 12 volt adaptor (according to the motor)
5. Timer (if you have a big aquaponic system and you need lots of food, a one minute timer will be fine. Otherwise you will need a seconds timer, which is more expensive)
6. Wood
7. Plumbing pipes
Step 3: Making a Plastic Drill
I use a heating device and a stripe of acrylic to make my own light plastic drill. After heating the acrylic up, you twist it. Don't make the stripe too thick because then it folds up around itself and doesn't twist.
Step 4: Explanatory Video
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • First Time Author Contest
    • Metal Contest
      Metal Contest
    17 Comments
    abigailm41
    abigailm41
    Question 2 years ago on Introduction
    Do you still have th explanatory video? I would like to make this for my auquaponics greenhouse for my school! Im just confused about the motor that allows the drill to spin
    sjanssen
    sjanssen
    3 years ago
    what RPM was the DC motor?
    BullwinkleII
    BullwinkleII
    8 years ago on Step 3
    This is a really good home made auger.
    Perfect.
    - 120 things in 20 years
    BullwinkleII
    BullwinkleII
    Perfect!
    ddee6
    ddee6
    8 years ago on Introduction
    Just great! I was looking to learn more about this and possibly construct one from recyclable materials and your instruct fit's the build. Thanks to you & Aquaponics Survival Communities via facebook, I am able to find this information.
    jkimm7
    jkimm7
    nice job now... BIG BOX!!!!
    really really big
    Dr.Jero
    Dr.Jero
    9 years ago on Step 4
    Muy buenas! Congratulaciones! Have you tried to load the bottle to top and run it? I am looking at different designs to make 5L feeders that are robust...Gracias!
    ede566
    ede566
    nice idea, but the trasparent tube inclinate is better the food drop more easy and dont come back ! :)
    tinker234
    tinker234
    9 years ago on Introduction
    could i use a largeer tank like the ones for water dispensers like in offices
    OruKun
    OruKun
    I EFFIN LOVE YOU!!!! Couldnt for the life of me think of using a acrylic or plastic pvc strip to bend it like an archemedes screw. I was overthinking of using metal or finding a store that sell them >.< ($50 and the size is 5inch diameter, very exessive for a home grower). Although a suggestion of mine is having the length for the food to travel be decreased. Shorter equals faster, less materials and less work with bending the homade hopper screw. THANK YOU SO MUCH!!!
    roberts1010
    roberts1010
    to deqwer, you could plug your unit into a timer like a light timer and set it to feed your fish like twice a day or somthing and you could set it to only feed for a minute or 2
    deqwer
    deqwer
    i see you feed alot in the video what if i only want to feed a little amount of fish food
