DIY Bbq in Action
Intro: DIY Bbq in Action
BBQ grill made by Alex Fleming
STEP 1: MATERIALS
What you will need:
1 Altoids tin case with a lid that has no embrossings, or engraved text. It should be flat.
1 Xacto knife
1 coat hanger
1 pair of needle nose pliers
1 pair of regular flat head pliers
sand paper ranging from 100 grit to 2000 grit( for maximum style and performance)
1 Xacto knife
1 coat hanger
STEP 2: The Lid
Get your knife and cut the lid where you see the black line so it should look like this:
STEP 3: The Grill
Take a coat hanger and cut the hook of of it then bend the hanger with the two pliers so it should look like this. You want to make the grill act like a "spring" so when you put the grill in place, it won't come out unless you squeeze the ends of the grill together.
STEP 4: Assembly
After you finish making each part, assemble the grill so the grill fits snugly inside the brim of the Altoids tin case. Put the lid back on. It should close all the way if made properly. then sand the product so it looks like the images below. That is optional! You're done!
STEP 5: Video of EBq BBQ in Action
This is the finished grill! The spill is from Reiley. He accidentally poured too much fuel into the grill. But that's okey.
85 Comments
awang8 15 years ago
scienceguy8 15 years ago
dark sponge 15 years ago
wesley1234 15 years ago
Fred82664 15 years ago
Heywasup 14 years ago
DaveC318 4 years ago
ebqbbqmaster 14 years ago
ricochet3212 14 years ago
junits15 15 years ago
junits15 14 years ago
pppoootttzzz 14 years ago
