DIY Camera Shoulder Rest
Intro: DIY Camera Shoulder Rest
Do you use a camcorder, do you have problems with the shakes, then you need one of these. It bolts to the tripod mounting on the camcorder and turns your camcorder into a shoulder mount.
Very easy to make and use for only 12 Euro.
Easily made from a aluminium gutter support. You might have to alter the length and the bend to suit your own camcorder. The Replacement sponge from a Plastic smoothener is used for the shoulder rest.
STEP 1: Get Your Gear Together.
You need the following:
1.) a aluminium gutter support
2.) and another aluminium gutter support
3.) The Replacement sponge from a Plastic smoothener
4.) 2 Bolts and washers M 10
5.) 1 bolt for the tripod mounting of your camcorder
STEP 2: Cut Off the Edges.
STEP 3: Drill Two Holes
Drill two 11 mm holes. The placement of the holes depends on the size of your camera.
STEP 4: Tighten the Two Bolds
STEP 5: Create a Threat for the Bold of Your Tripod Mounting.
I’ve used an old screw to create a threat. I know there are more professional ways of doing this, but I don’t have the right tools.
STEP 6: Attach the Tripod Mounting Bold
STEP 7: Cut Off a Strip of Rubber
Measure the width of the aluminium strip. Cut off a strip of rubber slightly wider than the aluminium strip.
STEP 8: Attach the Rubber to the Aluminium Strip
I’d used a roll of double sided tape, but perhaps it will be better to use glue.
STEP 9: Attach the Camera
Attach the camera and start to shoot great movies.
Please let me know if you find this instructable useful or not.
26 Comments
Summered 13 years ago
I'm going to try this one out and hope it improves my ergonomics using the camera :)
RemyOne 14 years ago
Ahahaha ik zie Teletubies :P
Runeshai 17 years ago
CurtisG 15 years ago
dfaw 15 years ago
henryfaber 15 years ago
jesse ferguson 17 years ago
guitarman63mm 15 years ago
mdmoose29 17 years ago
Mario1 15 years ago
jeremy91511 16 years ago
technodude92 16 years ago
Closet_RAt 16 years ago
lookatmygrlyfont 17 years ago
sifu17055 17 years ago
ricejuh 17 years ago
holeman666 17 years ago
gw812 17 years ago
bowakowa 17 years ago
henryfaber 17 years ago
