DIY Camping Hammock
Intro: DIY Camping Hammock
This instructable features how to make a "Do It Yourself" Camping Hammock- (This is my first instructable, so bear with me...)
STEP 1: Materials Needed
Materials Needed:
1.) Large peice of ripstop nylon - 3 & 2/3 yards - You can get this at most sewing stores: JoAnns, Michaels, even Walmart (if they have a sewing section).
2.) Sewing machine
3.) Paracord( any type of rope will do, as long as it will hold your weight. I prefer paracord for it's size and weight capacity). The length of the cord will depend on how far apart the trees you hang the hammock from are.
4.) 2 carabeeners or other type of clip, which must be able to hold your weight as well.
A.) I have also seen people make hammocks out of bed sheets( perferrabley large ones)
2.) Sewing machine
STEP 2: Length-wise "Clean Up" of the Edges
1.) Use a sewing machine to hem the edges of the hammock. This will keep the edges neat and prevent the fabric from fraying.
2.) Folding the edge over as you sew, use a straight stitch and sew down the longer side of the fabric. (Not width-wise, but length-wise).
STEP 3:
STEP 4: Width-wise "Clean Up"
1.) Following the same instructions as the Length-wise "Clean Up" (Steps 2 and 3), hem the fabric's width.
STEP 5: Making Space for Rope
1.) Take the 2 short ends and fold them in to make space for the rope ( I folded the ripstop down 3 inches and stitched along that line). This leaves enough room for any type of rope or chord, large or small. It will serve as a "tube" for the rope to lace through.
2.) Repeat on the other end.
STEP 6: Insert Rope
1.) Insert the rope into the space that you just sewed and sinch the hammock until it is tight.
You dont have to do it this way you can whip the ends of the hammock and the benefit from this is that based upon the way you whip the ends it will change the way the hammock lays when you are in it.
This was a question put in by one of the viewers-
says:
i don't quite understand the last step... what do you mean by: You don't have to do it this way you can whip the ends of the hammock and the benefit from this is that based upon the way you whip the ends it will change the way the hammock lays when you are in it. (what is a whip?)
lerickson says:
Do you know when rope frays and if it is synthetic you can melt it to stop the fraying? Well if it is not synthetic rope then you have tto whip the ends of the rope. There are many other resources that can show you how to whip the hammock- here is one http://www.imrisk.com/hammockwhipping/hammockwhipping.htm
this will show you how to do
says:
lerickson says:
STEP 7: Hang
1.) Hang the hammock from two trees. (The two as pictured are about 25 feet apart. 13 to 18 feet would be ideal).
STEP 8: Furnishing the Hammock
1.) Add a rubber mat or some sort of insulation to the bottom of your hammock. This rubber mat is especially useful when the sun goes down and it gets chilly.
2.) You may also add a sleeping bag and lay it on top of the mat.
59 Comments
matmore74 12 years ago
NathantheGray 7 years ago
larslovespeace 7 years ago
Solomojo 7 years ago
larslovespeace 13 years ago
Myklknife 12 years ago
Poppa Chubby 8 years ago
You could also try using more lengths of cord for longer runs. Double, triple or even quadruple strands or more would reduce stretching.
larslovespeace 12 years ago
KravenTheHunter 12 years ago
BennitoJuarez 9 years ago
Just for clarity, the type of nylon that can be purchased at Joanne's is heavy duty ripstop nylon and is more than enough to be used for hammocks. The lightest possible that can be "safely" used is no less than 1.1 oz, (measured 1.1oz per yard. 1.1 oz is not recommended for anyone over 200 lbs, however.
1.7oz, or 1.6 oz seems to be the normal weight that people prefer for hammock making. I'm not sure what the exact weight of nylon that Joanne's sells, but it's well above 1.7 oz.
Drapes and other bedding type fabric should be avoided unless they are confirmed to be made of 100% polyester or nylon. Cotton or other materials can fail. Many DIY'ers use polyester taffeta tablecloths for hammocks as they're cheap, super strong, and already have edges sewn.
bigg.goocher 9 years ago
I bought a single panel of old drapes at the thrift store... $5... then I tied very tightly knotted rope to each end, bunching the fabric accordion style. I attached my carbiners there. I use nylon ratchet straps to go around the trees and snap on at each end. Easy peasy. Been using in my yard for 2 summers now and still going strong.
walloon 12 years ago
I'm just having a *really* hard time finding the fabric that can work. I've tried all the usual fabric stores but they aren't sure if the fabric can hold the weight.
Any advice anyone?
Great instructable! keep it up!
cwebb11 9 years ago
hammockguy 12 years ago
sidmarx 10 years ago
