DIY Computer Flatfile Database Program Template.
Introduction: DIY Computer Flatfile Database Program Template.
About: computoman.blogspot.com Bytesize articles instead of a trilogy in one post.
Database is sort of a file cabinet. with a little bit of code we can emulate a file cabinet with a computer. This program is not relational, nor will it replace a full commercial program. For experimentation purposes it is alright. It is buggy and not idiot proof either. Use at you own risk. This program can be used with quickbasic, qibasic or true variants such as qb64. It will not work with Freebasic. You may remember the spreadsheet we did. (https://www.instructables.com/id/DIY-computer-spreadsheet-program-template/).
This program supports: Alpha-numeric (letters and numbers)
                                      Numeric (numbers)
                                      Logical (1 character field)
                                      Date:
                                      Time:
                                      Alpha (Characters, but not numbers)
Plan to update this program and then do a follow up program that will print out invoices. Then be built into a whole accounting system.
Step 1: The Code.
The code is down-loadable from the attachment. The file is qbasic source code.  Putting the code in the instructable chokes it so the file had to be uploaded and made available as a download.  Have not tried it on anything other than Linux or Redmond based systems. You will have to rename the file so that it does not have the .txt extension to work.
'* program : LizzyDB.bas          *
'* author  : Computothought       *         s
'* last fix: Jan.  1, 1996        *
'* Note    : Pc clone flat file   *
'*           database from what   *
'*           we learned at school.*
Step 2: Structure.
The main parts of the program menus are as follows:
Main menu > Design, build, organize, report.
Design (Filename, screen size, and exit code,
Build menu > Append, Behold, Change, Delete.
Organize (sort records b key.
Report: printout to disk.
Step 3: Datafiles.
Four basic files are generated: meta, data, index and the report file. Some of the files you could edit manually, but you have to be careful the datafile structure is not disturbed.
Filename.met (Meta data  or how the screens are presented.).
$ cat ab.met
 5 ,-1,Name, 25 ,A, 0 ,Address, 25 ,A, 0 ,City, 15 ,A, 0 ,State, 2 ,A, 0 ,Zip, 5 ,N, 0 ,
Filename.key (sort key)
$ cat ab
Filename.ndx (record numbers in sorted order.
$ cat ab.ndx
Filename.dat (the data file)
$ cat ab.dat
Equine Test              12345 Test               Test city      TX88441Angel Bark               434 Heaven               Sky City       TX32165
Filename.rpt (the report file)
$ cat ab.rpt
         This is a report of file: ab
         On 12-15-2011 at 05:44:31.
         Page number:  1
Name                     Address                  City           StZip
Angel Bark               434 Heaven               Sky City       TX32165  2
         Page number:  2
Equine Test              12345 Test               Test city      TX88441  1
Step 4: Possible Improvements.
Writing a program is just like playing a game, except you get to make the rules as you go along. There is alway room to improve. Things you could easily implement are:
Import/export.
Record search.
Better error checking
Idiot proof.
Multiple keys.
Relational database features.
etc.
Step 5: Line Editor Template.
If you are into writing code, them you might like this former instructable.
Step 6: A Simple Database in Other Forms.
GNU Free Documentation License 1.2
Simple database You are encouraged to solve this task according to the task description, using any language you may know.
Write a simple tool to track a small set of data. The tool should have a command line interface to enter at least two different values. The entered data should be stored in a structured format and saved to disk.
It does not matter what kind of data is being tracked. It could be your CD collection, your friends birthdays, or diary.
You should track the following details:
A description of the item. (e.g., title, name) A category or tag (genre, topic, relationship such as “friend” or “family”) A date (either the date when the entry was made or some other date that is meaningful, like the birthday); the date may be generated or entered manually Other optional fields
The command should support the following Command-line arguments to run:
Add a new entry Print the latest entry Print the latest entry for each category Print all entries sorted by a date
The category may be realized as a tag or as structure (by making all entries in that category subitems)
The file format on disk should be human readable, but it need not be standardized. A natively available format that doesn't need an external library is preferred. Avoid developing your own format however if you can use an already existing one. If there is no existing format available pick one of: JSON, S-Expressions, YAML, or others.
See also Take notes on the command line for a related task. Contents
C
COBOL
Java
Python
UNIX Shell
Step 7: A Simple Database in C.
A simple database in C with some error checking, even. A quick test with Valgrind revealed no obvious memory leaks. The following data was used for testing. -> database.csv
"Soon Rising","Dee","Lesace","10-12-2000","New Hat Press" "Brave Chicken","Tang","Owe","04-01-2008","Nowhere Press" "Aardvark Point","Dee","Lesace","5-24-2001","New Hat Press" "Bat Whisperer, The","Tang","Owe","01-03-2004","Nowhere Press" "Treasure Beach","Argus","Jemky","09-22-1999","Lancast"
$ ./db
Usage: ./db [commands] -c Create new entry. -p Print the latest entry. -t Print all entries sorted by title. -d Print all entries sorted by date. -a Print all entries sorted by author
$ ./db -d
-d Print all entries sorted by date. Title : Treasure Beach Author : Argus Jemky Date : 09-22-1999 Publication : Lancast
Title : Soon Rising Author : Dee Lesace Date : 10-12-2000 Publication : New Hat Press
Title : Aardvark Point Author : Dee Lesace Date : 05-24-2001 Publication : New Hat Press
Press Enter to continue.
Title : Bat Whisperer, The Author : Tang Owe Date : 01-03-2004 Publication : Nowhere Press
Title : Brave Chicken Author : Tang Owe Date : 04-01-2008 Publication : Nowhere Press
Step 8:
Step 9: A Simple Database in Cobol.
This is a souped-up version of the task from Take notes on the command line. It stores the current date, a tag, a title and a note as an entry in a file. The database produced is not particularly human-readable or easy to modify, but it is in a well-structured format.
Works with: OpenCOBOL
Compile with:
$ cobc -x -free db.cob
Sample session:
$ ./database -c "Reminder" "Bob's Birthday" "Buy birthday present for Bob." $ ./database -c "Wishlist" "Beethoven" "Beethoven's Ode to Joy" $ ./database -c "Reminder" "Add to Simple Database" "Add brainf*** example for Simple Database on Rosetta Code." ... $ ./database -f "Mozart" An entry with that title was not found. $ ./database -t Date added: 2013/08/13 Tag: Reminder Title: Bob's Birthday Contents: Buy birthday present for Bob. Date added: 2013/08/13 Tag: Reminder Title: Add to Simple Database Contents: Add brainf*** example for Simple Database on Rosetta Code. Date added: 2013/08/13 Tag: Wishlist Title: Beethoven Contents: Beethoven's Ode to Joy
$ ./database -r "Beethoven" $ ./database -l Date added: 2013/08/13 Tag: Reminder Title: Add to Simple Database Contents: Add brainf*** example for Simple Database on Rosetta Code. $
Step 10: A Simple Database in Java .
Java
Translation of: D Works with: Java version 7
C:\temp>java -jar SimpleDatabase.jar add item1
C:\temp>java -jar SimpleDatabase.jar add item2
C:\temp>java -jar SimpleDatabase.jar add item3 cat3
C:\temp>java -jar SimpleDatabase.jar add item4 cat3
C:\temp>java -jar SimpleDatabase.jar add item5 cat3
C:\temp>java -jar SimpleDatabase.jar latest item1,2014-06-03 19:30:05,none
C:\temp>java -jar SimpleDatabase.jar latest cat3 item3,2014-06-03 19:30:14,cat3
item4,2014-06-03 19:30:20,cat3
item5,2014-06-03 19:30:23,cat3
C:\temp>java -jar SimpleDatabase.jar all item1,2014-06-03 19:30:05,none
item2,2014-06-03 19:30:08,none
Step 11: A Simple Database in Python 3.
Sample session (Unix)
paddy3118:~$ ./simple_db.py -h usage: simple_db.py [-h] [-d DESCRIPTION] [-t TAG] [-f FIELD FIELD] {add,pl,plc,pa}
positional arguments: {add,pl,plc,pa} add: Add a new entry pl: Print the latest entry plc: Print the latest entry for each category/tag pa: Print all entries sorted by a date
optional arguments: -h, --help show this help message and exit -d DESCRIPTION, --description DESCRIPTION A description of the item. (e.g., title, name) -t TAG, --tag TAG A category or tag (genre, topic, relationship such as “friend” or “family”) -f FIELD FIELD, --field FIELD FIELD Other optional fields with value (can be repeated)
$ ./simple_db.py -d Book -f title 'Windy places' -f type hardback --tag DISCOUNT add Writing record to _simple_db_db
$ ./simple_db.py -d Book -f title 'RC spammers' -f type paperback -t DISCOUNT add Writing record to _simple_db_db.py
$ ./simple_db.py -d Book -f title 'Splat it' -f type hardback -f special 'first edition' -t PREMIUM add Writing record to _simple_db_db.py
$ ./simple_db.py pl Getting last record from _simple_db_db.py Namespace(description='Book', field=[['title', 'Splat it'], ['type', 'hardback'], ['special', 'first edition']], tag='PREMIUM')
$ ./simple_db.py plc Getting latest record for each tag from _simple_db_db.py Namespace(description='Book', field=[['title', 'Splat it'], ['type', 'hardback'], ['special', 'first edition']], tag='PREMIUM') Namespace(description='Book', field=[['title', 'RC spammers'], ['type', 'paperback']], tag='DISCOUNT')
$ ./simple_db.py pa Getting all records by date from _simple_db_db.py Namespace(description='Book', field=[['title', 'Windy places'], ['type', 'hardback']], tag='DISCOUNT') Namespace(description='Book', field=[['title', 'RC spammers'], ['type', 'paperback']], tag='DISCOUNT') Namespace(description='Book', field=[['title', 'Splat it'], ['type', 'hardback'], ['special', 'first edition']], tag='PREMIUM')
$ cat _simple_db_db.py Namespace(_date='2012-08-18T06:02:44.947091', description='Book', field=[['title', 'Windy places'], ['type', 'hardback']], tag='DISCOUNT') Namespace(_date='2012-08-18T06:03:11.477429', description='Book', field=[['title', 'RC spammers'], ['type', 'paperback']], tag='DISCOUNT') Namespace(_date='2012-08-18T06:03:34.319799', description='Book', field=[['title', 'Splat it'], ['type', 'hardback'], ['special', 'first edition']], tag='PREMIUM')
Step 12: A Simple Database in Sh.
Sample usage (assuming script is named "sdb"):
$ sdb create CDs Create DB `CDs'
$ sdb add CDs Bookends
$ sdb prop CDs Bookends artists "Simon & Garfunkel"
$ sdb add CDs "Ode to joy"
$ sdb prop CDs "Ode to joy" artist "Beethoven"
$ sdb tag CDs Bookends rock folk
# I'm not sure about this
$ sdb tag CDs "Ode to joy" classical
$ sdb show CDs Bookends Description: artists: Simon & Garfunkel Tags: folk rock
$ sdb prop CDs "Ode to joy" Description "Sym. No. 9"
$ sdb show CDs "Ode to joy" Description: Sym. No. 9 artist: Beethoven Tags: classical
$ sdb last-all CDs Tag: classical Ode to joy Tag: folk Bookends Tag: rock Bookends
$ sdb drop CDs Delete DB `CDs'
Be the First to Share
    • Jewelry Challenge
      Jewelry Challenge
    • One Board Contest
      One Board Contest
    • New Year, New Skill Student Design Challenge
