DIY Cosplay Extendable Baton
Intro: DIY Cosplay Extendable Baton
this is a cosplay baton I made from a broken telescopic fishing rod(got it from someone, so I have no idea how much money it costs)
you could cosplay Aiden Pearce with this or someone else
*DISCLAIMER*
I am not responsible for what you do with this!
check your country and or state laws if this is legal or not!
*DISCLAIMER*
STEP 1: Stuff You Need
-ductape
-a saw(both iron and normal will do)
-a ruler(to see how long it is)
-a (broken) telescopic or folding fishing rod(a wooden one ofcourse!)
-(optional) a (rubber) ring for the hand guard
grab the (broken) rod and saw it in the wanted length(mines 35cm collapsed and 65cm extended) be sure to saw the biggest part a bit longer!
now put ductape on the bottom to the rod can`t go out, and use ductape for grip if wanted
now put a LITTLE bit of ductape on the tip so it stays in
and done it is!
and done it is!
STEP 2: How to Extend/collaps It
to extend; swing it away from you and.it will extend(tapping it against your hand/knee will help losening it if it`s stuck)
to collapse; hit the tip against the ground a few times to make it lose
