DIY Footswitch for Zoom B3 and Zoom G3
Intro: DIY Footswitch for Zoom B3 and Zoom G3
This is the tutorials for footswitch modification Zoom G3 or Zoom B3
STEP 1: Materials and Tools
actually footswitch modification for zoom G3 or B3 tutorial on this site , but due to popular demand tutorials , with some images taken from here , google and pictures of my personal collection
material
Casing/enclosure
Momentary footswitch
Trs connector female and male 1/8 inch (stereo)
cables
soldering tin
isolation
tools :
Solder , cutter , cable pliers , screwdriver plus ( + ) , an electric drill and drill bit 5 mm and 12 mm
STEP 2: Step 1
Open the casing bolts under B3 or G3
STEP 3: Step 2
Open the battery cable connections
STEP 4: Step 3
Open the bolt on pcb and jack on the casing , and open the pcb
STEP 5: Step 4
After the pcb open , prepare the cable and solder , then solder the parts shown in the picture , connect the cable to the connector female TRS
STEP 6: Step 5
Make a hole using a drill on the chassis, the position is up to you, need to plan exactly, so that not one of the holes and do not interfere with other components
STEP 7: Step 6
Post a TRS connector on the casing and reassemble your effect , do not forget isolation trs conectornya , not to be connected to ground
STEP 8: Step 7
Now make a hole in the casing footswitch , with an electric drill and drill bit 12mm
and Create a connection to the footswitch
STEP 9: Step 8
assembly the footswitch to the casing , and the footswitch is ready for use
4 Comments
VincenzoM17 4 years ago
CarraN 4 years ago
if you don't want to drill your Zoom, see that instructable:
https://www.instructables.com/id/Arduino-Based-Boss-GP-10-Program-Changer/
cheers!
gigin 9 years ago
Nice job,
ini dimana mas, saya gigin salam kenal..
momon_crot 9 years ago
