Introduction: DIY Infrared Remote Control for Android
Almost everyone uses infrared remote controls at home and developing and using infrared on most of the Android Devices requires the usage of external hardware. You will learn about the design details, the tools and software used to design a project that enables any Android device to control infrared equipment. You will get an introduction to the hardware functionality of Irdroid v1.0 modules, battery powered infrared remote control modules that connects to the Android device Audio jack. The second module takes advantage of the Bluetooth A2DP protocol and allows the user to listen to a music witlessly and the ability to control IR equipment all in one device.
Irdroid is a universal infrared remote control for smartphones, tablets and other devices, working with the Google Android operating system. To control your favourite TV, STB or DVD, you need to download the Irdroid APP for Android and to purchase a Irdroid module.. The Irdroid application is available for download from the Android Market and from Appslib (for android tablets) The biggest benefit of Irdroid is that it is compatible with the LIRC project in which database, there are a lot of supported equipment vendor’s some of the famous are Samsung, Sony, Motorola, LG, Panasonic, Philips and many, many more (see here – > http://lirc.sourceforge.net/remotes/).Another benefit for the Public is that the Irdroid application is free, open source and the source code can be downloaded from http://www.github.com/irdroid.
Features:
Free and open source application and open hardware module
Available from Android Market,AppsLib
Low cost Irdroid infrared module
Plug and play design
Extended remote control range – 10+ meters
Small Dimensions 17×43,2 mm
Design based on the principle KISS (Keep it simple stupid!)
Let’s start with the Hardware:
The module’s main task is to amplify the signal, generated from the app and to provide an IR interface to the relevant Android device. The active amplification is necessary, because the output signal from an Android device is not powerful enough to light up IR LEDs, as well as to provide a decent remote control range.
The module practically amplifies the generated waveform from the app and emits IR Light via the IR LEDs at 940nm wavelength. The input of the module is provided by the Android Device 3.5mm Audio jack.
The Left and The Right audio channels are used, (GND) is not connected. The amplification is done using an inexpensive LM386-M1 mono audio amplifier which is configured for a gain of 200 times.
This configuration assures enough power @ 6V in order to achieve a remote control distance of about 10 meters.
Тhe Irdroid app is responsible for generating a 19kHz audio tone. The infared data is modulated on the 19kHz sine wave. The signal is amplified via the LM386 audio amplifier and rectified via the two IR leds, doubling the frequency to 38kHz. The first IR led rectifies the positive halfwave of the audio signal and the second IR led the negative halfwave of the signal.
The LM386 mono audio amplifier is configured to amplify the signal 200 times so that the radiated IR light power is enough to achieve a remote control distance of about 10 meters.
Most of the components are SMD (surface mount) only the Jumper, the two IR Leds, the Battery Holder and the audio jack are coventional parts. The download section at http://www.irdroid.com contains a zip archive of the schematics and the production files of the module.
You could use the schematics and the production files to produce boards using your favourite printed circuit board manufacturer. In most of the companies offering pcb manufacturing service you will find out that they could also solder the SMD components for you, as well as to build complete modules.
All, the documentation , schematics, user's manual and a handbook for building your own Irdroid IR module is attached to this instructable.
for more information and support http://www.irdroid.com
