Introduction: DIY Simple Homemade Motor
This a very simple motor which is called a 'Homopolar motor'. It's a great example of how a magnetic field is produced when electricity is passed through a conductor. It is a fun project and only takes a few minutes to make.
So, let's get started!
Step 1: Materials
All you need is :
1) AA battery
2) Neodymium magnets (You can also use a couple of strong magnets)
3) Conductive wire
4) Wire cutters / pliers
That's it!
Step 2: Shaping the Wire
You can shape the wire any way you want - keep in mind there should be a tip which can balance on the end of the battery and the other end should curl around the magnets.
Step 3: Assembling the Motor
Stick the AA battery (Positive terminal up) on the magnets. Then, put the wire onto the battery and the magnets.
Step 4: The End
As soon as it is assembled, it should start spinning!
Thanks for seeing this instructable. If you liked it please favourite and any suggestions will be welcome :)
Battery Powered Contest
7 Comments
8 years ago
home wall painting
9 years ago on Introduction
Great instructable! By the way the magnets you used were not neodimium, they were ceramic disk shaped magnets.
Reply 9 years ago
That's why I wrote "you could use a couple of strong magnets" because I didnt have neodymium magnets. Thanks for commenting :)
Very simple yet amazing instructable. I never would of guessed that would work!
Reply 9 years ago
Thanks!
You should post a video!
Reply 9 years ago
Yes, I might post one when I can access a proper camera. It came all blurry with the cellphone camera (The photos I took with)!
