DIY Simple Homemade Motor
Intro: DIY Simple Homemade Motor
This a very simple motor which is called a 'Homopolar motor'. It's a great example of how a magnetic field is produced when electricity is passed through a conductor. It is a fun project and only takes a few minutes to make.
So, let's get started!
STEP 1: Materials
All you need is :
1) AA battery
2) Neodymium magnets (You can also use a couple of strong magnets)
3) Conductive wire
4) Wire cutters / pliers
That's it!
STEP 2: Shaping the Wire
You can shape the wire any way you want - keep in mind there should be a tip which can balance on the end of the battery and the other end should curl around the magnets.
STEP 3: Assembling the Motor
Stick the AA battery (Positive terminal up) on the magnets. Then, put the wire onto the battery and the magnets.
STEP 4: The End
As soon as it is assembled, it should start spinning!
Thanks for seeing this instructable. If you liked it please favourite and any suggestions will be welcome :)
7 Comments
rsiddiqui4 9 years ago
AH Electronics 9 years ago
Great instructable! By the way the magnets you used were not neodimium, they were ceramic disk shaped magnets.
aru12295 9 years ago
That's why I wrote "you could use a couple of strong magnets" because I didnt have neodymium magnets. Thanks for commenting :)
GuyTech797 9 years ago
Very simple yet amazing instructable. I never would of guessed that would work!
Thanks!
Danger is my middle name 9 years ago
You should post a video!
Yes, I might post one when I can access a proper camera. It came all blurry with the cellphone camera (The photos I took with)!
